Adjusting Contrast on TI-Nspire Calculator
  1. Adjusting Contrast on TI-Nspire Calculator, Adjusting Contrast on TI-Nspire Calculator: step 1, image 1 of 2 Adjusting Contrast on TI-Nspire Calculator, Adjusting Contrast on TI-Nspire Calculator: step 1, image 2 of 2
    • Remove the front protective cover by sliding it off of the calculator.
    • Press the "ON" button to turn on the calculator.
    Ask FixBot
  2. Adjusting Contrast on TI-Nspire Calculator: step 2, image 1 of 3 Adjusting Contrast on TI-Nspire Calculator: step 2, image 2 of 3 Adjusting Contrast on TI-Nspire Calculator: step 2, image 3 of 3
    • Press the "2ND" button at the top left portion of the keypad. An arrow pointing up will appear at the top left corner of the screen.
    • Press and hold the "UP" arrow until you have increased the contrast to a level that is easily visible for yourself. A common level to set the contrast is 5.
    • To decrease the contrast, press the "2ND" button, then press and hold the "DOWN" arrow.
    Ask FixBot
Now you should have the image contrast set to your preferences.
Alan Wong
63 Reputation
1 Guide authored
Cal Poly, Team 7-52, Forte Fall 2012 Member of Cal Poly, Team 7-52, Forte Fall 2012
CPSU-FORTE-F12S7G52
5 Members
15 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 38
All Time: 6,322
