Up to 20% off select tools
Adjust Nintendo DS picture
Views: 6.5K
View statistics:
Past 24 Hours:
9
Past 7 Days:
50
Past 30 Days:
241
All Time:
6,471
Comments: 2
2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
In this guide, you can eliminate flickering from both screens
    1. Adjust Nintendo DS picture, Adjust Nintendo DS picture: step 1, image 1 of 1
      • First check if the DS has image flickering. It is best to do this with a still image, such as the boot screen.
      • But make sure the backlight is on.
      Ask FixBot
    2. Adjust Nintendo DS picture: step 2, image 1 of 2 Adjust Nintendo DS picture: step 2, image 2 of 2
      • Loosen the Phillips #00 screw on the battery compartment
      • remove the cover
      Ask FixBot
    3. Adjust Nintendo DS picture: step 3, image 1 of 1
      • in these two openings are potentiometers responsible for the image.
      • Above is for the Upper LCD
      • Below for the Lower LCD
      • It's best to check both of them out.
      Ask FixBot
      • Now you can turn on the console and make sure the backlight is on.
      Ask FixBot
    4. Adjust Nintendo DS picture: step 5, image 1 of 1
      • Then you can turn left and right with the Phillips #00 screwdriver to adjust the picture.
      • But always take a look at the screens to get a good picture
      • It is also important not to turn too fast and not too far. The trick is to do this slowly and gently.
      Ask FixBot
    5. Adjust Nintendo DS picture: step 6, image 1 of 1
      • If everything fits and the LCD screens display the picture well, you can close the battery door.
      Ask FixBot
Close the battery compartment with the battery inside
2 other people completed this guide.
Special thanks to these translators:
de en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
Author
with
Patrick Stork
424 Reputation
1 Guide authored
2 Guide Comments
obrigado exelente
Andre Miranda - Reply Share
BOA NOITE
Gostaria de saber se as telas superior e inferior sao iguais??
Past 24 Hours: 9
Past 7 Days: 50
Past 30 Days: 241
All Time: 6,471
