AcuRite 02081M Observer Repair Battery,LCD Screen,Push Button Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
60
All Time:
555
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
The console itself has dual levels of connectivity – the sensor uses RF (915 Mhz) while the console connects directly to your router (2.4 GHz).
Parts
    1. AcuRite 02081M Observer Repair Battery,LCD Screen,Push Button Replacement, Battery Replacement: step 1, image 1 of 1
      • First, unscrew the 4 M2x1.5-7 screws (7mm length) from the back of the device using a number 1 Phillips screwdriver.
      • Pry the front silver panel away from the back black panel with a plastic opening tool.
      Ask FixBot
    2. AcuRite 02081M Observer Repair Battery,LCD Screen,Push Button Replacement, Step 2: step 2, image 1 of 1
      • Next, the ribbon cable needs to be carefully removed from the back of the LCD screen.
      • Use a plastic opening tool to press the black bar towards the ribbon and away from the white bar gently. This will release the ribbon.
      Ask FixBot
    3. AcuRite 02081M Observer Repair Battery,LCD Screen,Push Button Replacement, step 3: step 3, image 1 of 1
      • Remove the 4 M2x1.5-7 screws (7mm length) from the green PCB board.
      • This will result in two pieces, the back black cover and the PCB board.
      Ask FixBot
    4. AcuRite 02081M Observer Repair Battery,LCD Screen,Push Button Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • The battery can then be popped out using precision tweezers and replaced with a new one.
      Ask FixBot
anhut51190
281 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 60
All Time: 555
