Up to 20% off select tools
Acrylic Nail Tip Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
70
All Time:
1,075
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Hitting an acrylic nail on an object often comes with pain, and the full process of applying acrylic nails can take hours. Thankfully, there is no need to go to a nail shop or start the full process of applying nails over. This guide demonstrates how to repair a broken nail in a timely manner.
If you are sensitive to strong odors, opening a window, using a fan, or wearing a mask may be helpful; liquid monomer odor is extremely strong. Having a glass bowl with a lid also helps reduce odor.
Before starting, make sure you have all of the tools prepared, as the process requires you to move quickly. Step 6 requires you to collect the acrylic powder onto the brush after dipping it in the liquid monomer. From there, you have to quickly place the acrylic onto the nail and smooth it out before it hardens too much for you to maneuver and shape it.
    1. Acrylic Nail Tip Replacement, Acrylic Nail Tip: step 1, image 1 of 1
      • File the nail in a back-and-forth motion with the nail file on the accessible part of the natural nail until it is no longer smooth.
      • Try not to file the acrylic nail that is is still attached to your natural nail, as it will not fit the part that broke.
      Ask FixBot
    2. Acrylic Nail Tip Replacement: step 2, image 1 of 1
      • Carefully place a drop of nail glue on the natural nail and let the glue sit for about 5 seconds.
      • Do not use more than 1-2 drops of nail glue.
      Ask FixBot
    3. Acrylic Nail Tip Replacement: step 3, image 1 of 2 Acrylic Nail Tip Replacement: step 3, image 2 of 2
      • Place a nail tip in its original position and hold it in place for about 20 seconds, or until it is fully dry.
      Ask FixBot
    4. Acrylic Nail Tip Replacement: step 4, image 1 of 2 Acrylic Nail Tip Replacement: step 4, image 2 of 2
      • Pour 30 milliliters of monomer in a small glass bowl.
      • Liquid nail monomer has a strong odor and is highly flammable.
      • Do not reuse the glass bowl for any food products because of possible chemical residue.
      Ask FixBot
    5. Acrylic Nail Tip Replacement: step 5, image 1 of 3 Acrylic Nail Tip Replacement: step 5, image 2 of 3 Acrylic Nail Tip Replacement: step 5, image 3 of 3
      • Dip the brush in the monomer and lightly tap it on the paper towel to remove the excess.
      Ask FixBot
    6. Acrylic Nail Tip Replacement: step 6, image 1 of 2 Acrylic Nail Tip Replacement: step 6, image 2 of 2
      • Place the tip of the brush in clear acrylic powder at about an 80-degree angle; collect it on one side of the brush.
      Ask FixBot
    7. Acrylic Nail Tip Replacement: step 7, image 1 of 3 Acrylic Nail Tip Replacement: step 7, image 2 of 3 Acrylic Nail Tip Replacement: step 7, image 3 of 3
      • Apply the acrylic powder to the nail, and in a dabbing, downward motion, smooth the acrylic over the nail from top to bottom.
      Ask FixBot
    8. Acrylic Nail Tip Replacement: step 8, image 1 of 1
      • Place the nail under the UV/LED lamp until hard and firm.
      Ask FixBot
    9. Acrylic Nail Tip Replacement: step 9, image 1 of 3 Acrylic Nail Tip Replacement: step 9, image 2 of 3 Acrylic Nail Tip Replacement: step 9, image 3 of 3
      • Use a nail drill to file the nail to achieve an even acrylic coat by drilling in a side-to-side motion, working your way from top to bottom.
      • Use a speed of 7-9 on the nail drill.
      • If you do not have a nail drill, you can also use a nail file.
      Ask FixBot
    10. Acrylic Nail Tip Replacement: step 10, image 1 of 3 Acrylic Nail Tip Replacement: step 10, image 2 of 3 Acrylic Nail Tip Replacement: step 10, image 3 of 3
      • Buff the nail until it is smooth, and use a paper towel to wipe off excess powder.
      Ask FixBot
    11. Acrylic Nail Tip Replacement: step 11, image 1 of 3 Acrylic Nail Tip Replacement: step 11, image 2 of 3 Acrylic Nail Tip Replacement: step 11, image 3 of 3
      • Optional: coat the nail with clear polish.
      Ask FixBot
Finish Line
Author
with
Alysia Williams
222 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 70
All Time: 1,075
