Up to 20% off select tools
Acer X191 monitor Display Assembly Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
13
Past 30 Days:
77
All Time:
508
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Replace the display assembly from your Acer X191 monitor. The display assembly includes the front plastic frame, the LCD screen, and some metal armature on the back of the LCD screen.
    1. Acer X191 monitor Display Assembly Replacement, Stand: step 1, image 1 of 2 Acer X191 monitor Display Assembly Replacement, Stand: step 1, image 2 of 2
      • Lay the monitor on a flat surface, facedown.
      • Use a #1 Phillips screwdriver to remove the 4x 10.2mm screws securing the stand to the back panel.
      • Remove the stand from the back panel by pulling it up.
      Ask FixBot
    1. Acer X191 monitor Display Assembly Replacement, Back Cover: step 2, image 1 of 1
      • Remove the 2x 9.8mm Phillips #1 screws securing the back cover to the monitor.
      Ask FixBot
    2. Acer X191 monitor Display Assembly Replacement: step 3, image 1 of 2 Acer X191 monitor Display Assembly Replacement: step 3, image 2 of 2
      • Work your way around the monitor, putting the flathead screwdriver into the space between the front and back covers, and prying up.
      • Twisting the screwdriver can help, but you can easily mess up the plastic without getting anything out of it by doing so. Be cautious.
      • Ideally you want to pry at the locations that have the little gaps, which are locking mechanisms.
      • You should hear a poping sound and the back cover should lift a little if you are prying at the right locations.
      Ask FixBot
    3. Acer X191 monitor Display Assembly Replacement: step 4, image 1 of 3 Acer X191 monitor Display Assembly Replacement: step 4, image 2 of 3 Acer X191 monitor Display Assembly Replacement: step 4, image 3 of 3
      • I've highlighted the locations of the locking mechanisms for the back cover, try prying in these locations for the best results.
      • Right side of the monitor.
      • Top of the monitor.
      • Left side of the monitor.
      Ask FixBot
    4. Acer X191 monitor Display Assembly Replacement: step 5, image 1 of 1
      • On the bottom side, be careful not to pry on the monitor buttons.
      • Bottom of the monitor locking mechanism locations.
      Ask FixBot
    5. Acer X191 monitor Display Assembly Replacement: step 6, image 1 of 2 Acer X191 monitor Display Assembly Replacement: step 6, image 2 of 2
      • The monitor back cover will then pull right off.
      Ask FixBot
    1. Acer X191 monitor Display Assembly Replacement, Display Assembly: step 7, image 1 of 1
      • Remove the 2 pieces of yellow tape.
      • The bottom one have a thin sheet a metal on the underside which you need to take off too, if it does not come off with the tape.
      Ask FixBot
    2. Acer X191 monitor Display Assembly Replacement, Button board: step 8, image 1 of 3 Acer X191 monitor Display Assembly Replacement, Button board: step 8, image 2 of 3 Acer X191 monitor Display Assembly Replacement, Button board: step 8, image 3 of 3
      • The button board is secured to the front frame by 2 plastic locking mechanisms.
      • To remove, insert a Flathead screwdriver into the gap to push the locking mechanism back a little, while pulling up on the board.
      • I found it easier to do one side at a time.
      Ask FixBot
    3. Acer X191 monitor Display Assembly Replacement: step 9, image 1 of 3 Acer X191 monitor Display Assembly Replacement: step 9, image 2 of 3 Acer X191 monitor Display Assembly Replacement: step 9, image 3 of 3
      • Remove the bundled cable connector that is going to the top of the monitor. Grab the black tape that holds all the individual wires together, and pull gently.
      • Be careful to pull evenly on all the wires. You can do this by pulling strait out and not at an angle. Jiggling a little bit can help, but be careful.
      Ask FixBot
    4. Acer X191 monitor Display Assembly Replacement: step 10, image 1 of 3 Acer X191 monitor Display Assembly Replacement: step 10, image 2 of 3 Acer X191 monitor Display Assembly Replacement: step 10, image 3 of 3
      • Remove the bottom foil tape from the back of the LCD.
      • Be sure to keep it. It helps dissipate static to the ground while the screen is in use. I recommend leaving the side of the tape that is sticking to the shield, where it is.
      Ask FixBot
    5. Acer X191 monitor Display Assembly Replacement: step 11, image 1 of 3 Acer X191 monitor Display Assembly Replacement: step 11, image 2 of 3 Acer X191 monitor Display Assembly Replacement: step 11, image 3 of 3
      • Remove the remaining 2 pieces of foil tape from the back of the LCD.
      • Keep the pieces of foil tape. They help dissipate static to the ground while the monitor is being used. I recommend leaving on side stuck on the shield.
      Ask FixBot
    6. Acer X191 monitor Display Assembly Replacement: step 12, image 1 of 1
      • Remove the 4 connectors that bring power from the powerboard to the LCD.
      • The connectors have a plastic locking tab on them, and the available space make them very difficult to pull out.
      • Next step shows one way to remove them without too much trouble.
      Ask FixBot
    7. Acer X191 monitor Display Assembly Replacement, Removing the power cable connectors: step 13, image 1 of 3 Acer X191 monitor Display Assembly Replacement, Removing the power cable connectors: step 13, image 2 of 3 Acer X191 monitor Display Assembly Replacement, Removing the power cable connectors: step 13, image 3 of 3
      • Insert a Flathead screwdriver into the holes on the top of the shield. Lodge the tip between the socket and the connector and slowly push the connector out of it's socket.
      • Be very careful that you are NOT pushing on the socket itself, but the connector, ideally on the locking tab.
      Ask FixBot
    8. Acer X191 monitor Display Assembly Replacement: step 14, image 1 of 3 Acer X191 monitor Display Assembly Replacement: step 14, image 2 of 3 Acer X191 monitor Display Assembly Replacement: step 14, image 3 of 3
      • Use a Phillips #1 to remove the 4x 8.5mm screws that are securing the shield to the display assembly.
      • Pull the shield up carefully.
      • The power board and logic board are inside the shield.
      Ask FixBot
Author
with
Sam
920 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 77
All Time: 508
