Acer Travelmate 220 RAM Replacement
Views: 4.1K
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
104
All Time:
4,082
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Introduction
Go to step 1 ↓
These are common symptoms requiring the replacement of the RAM chips in an Acer Travelmate 220 include:
  1. The inability to turn your computer on.
  2. Your computer randomly crashing/turning off.
  3. Your computer randomly rebooting/turning on.
  4. The inability to install new programs to your computer.
Parts
Tools
    1. Acer Travelmate 220 RAM Replacement, RAM Chip: step 1, image 1 of 1
      • Place the computer with the bottom facing up.
      Ask FixBot
    2. Acer Travelmate 220 RAM Replacement: step 2, image 1 of 3 Acer Travelmate 220 RAM Replacement: step 2, image 2 of 3 Acer Travelmate 220 RAM Replacement: step 2, image 3 of 3
      • Locate the larger cover panel in the upper left hand corner of the computer.
      • Locate the Phillips screw holding the large cover panel in place.
      Ask FixBot
    3. Acer Travelmate 220 RAM Replacement: step 3, image 1 of 2 Acer Travelmate 220 RAM Replacement: step 3, image 2 of 2
      • Remove the located screw with the Phillips #00 screwdriver.
      Ask FixBot
    4. Acer Travelmate 220 RAM Replacement: step 4, image 1 of 1
      • Slide the large cover panel to the right, until you hear a click.
      Ask FixBot
    5. Acer Travelmate 220 RAM Replacement: step 5, image 1 of 2 Acer Travelmate 220 RAM Replacement: step 5, image 2 of 2
      • Place the plastic opening tool in the gap created to the left of the large cover panel.
      • Pry the cover panel up and remove it from the computer.
      Ask FixBot
    6. Acer Travelmate 220 RAM Replacement: step 6, image 1 of 2 Acer Travelmate 220 RAM Replacement: step 6, image 2 of 2
      • Locate the white plastic levers on each side of the two RAM chips.
      Ask FixBot
    7. Acer Travelmate 220 RAM Replacement: step 7, image 1 of 3 Acer Travelmate 220 RAM Replacement: step 7, image 2 of 3 Acer Travelmate 220 RAM Replacement: step 7, image 3 of 3
      • Locate the first RAM chip.
      • Push the plastic levers away from the first RAM chip.
      Ask FixBot
    8. Acer Travelmate 220 RAM Replacement: step 8, image 1 of 3 Acer Travelmate 220 RAM Replacement: step 8, image 2 of 3 Acer Travelmate 220 RAM Replacement: step 8, image 3 of 3
      • Lift the RAM chip from the compartment.
      • Repeat steps 7 and 8 to replace the second RAM chip.
      Ask FixBot
2 other people completed this guide.
Kevin A
55 Reputation
1 Guide authored
UW Stout, Team 5-5, Zhou Fall 2011 Member of UW Stout, Team 5-5, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G5
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 104
All Time: 4,082
