Acer Travelmate 220 Disc Drive Replacement
    1. Acer Travelmate 220 Disc Drive Replacement, Disc Drive: step 1, image 1 of 1
      • Flip your computer over so the bottom case is facing you.
      Ask FixBot
    2. Acer Travelmate 220 Disc Drive Replacement: step 2, image 1 of 1
      • Locate the sliding unlock button near the AC power input.
      Ask FixBot
    3. Acer Travelmate 220 Disc Drive Replacement: step 3, image 1 of 1
      • Slide the button in the direction of unlock and hold.
      Ask FixBot
    4. Acer Travelmate 220 Disc Drive Replacement: step 4, image 1 of 1
      • Gently pull the disk drive out.
      Ask FixBot
    5. Acer Travelmate 220 Disc Drive Replacement: step 5, image 1 of 3 Acer Travelmate 220 Disc Drive Replacement: step 5, image 2 of 3 Acer Travelmate 220 Disc Drive Replacement: step 5, image 3 of 3
      • Remove the four screws from the sides of the black plastic using a Phillips #00 screwdriver.
      Ask FixBot
    6. Acer Travelmate 220 Disc Drive Replacement: step 6, image 1 of 2 Acer Travelmate 220 Disc Drive Replacement: step 6, image 2 of 2
      • Remove the black plastic that covers the metal.
      Ask FixBot
    7. Acer Travelmate 220 Disc Drive Replacement: step 7, image 1 of 1
      • Locate the green chip on the back of the drive.
      Ask FixBot
    8. Acer Travelmate 220 Disc Drive Replacement: step 8, image 1 of 2 Acer Travelmate 220 Disc Drive Replacement: step 8, image 2 of 2
      • Remove the two screws securing the green chip.
      Ask FixBot
    9. Acer Travelmate 220 Disc Drive Replacement: step 9, image 1 of 1
      • Firmly pull off the green chip.
      Ask FixBot
    10. Acer Travelmate 220 Disc Drive Replacement: step 10, image 1 of 1
      • Insert the green chip in the new disk drive.
      Ask FixBot
Justin
62 Reputation
1 Guide authored
UW Stout, Team 5-5, Zhou Fall 2011 Member of UW Stout, Team 5-5, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G5
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 31
All Time: 5,308
