Acer Swift X N20C12 SSD (Solid State Drive) Replacement
    1. Acer Swift X N20C12 SSD (Solid State Drive) Replacement, Lower Case: step 1, image 1 of 1
      • Use a T5 Torx screwdriver to remove the eleven screws that secure the lower case.
      Ask FixBot
    2. Acer Swift X N20C12 SSD (Solid State Drive) Replacement: step 2, image 1 of 1
      • Insert an opening pick in the seam between the lower case and chassis.
      • Slide the pick around the perimeter while prying until the lower case releases.
      • Remove the lower case.
      Ask FixBot
    1. Acer Swift X N20C12 SSD (Solid State Drive) Replacement, SSD: step 3, image 1 of 1
      • The SSD is located to the right of the battery.
      Ask FixBot
    2. Acer Swift X N20C12 SSD (Solid State Drive) Replacement: step 4, image 1 of 1
      • Use a Phillips screwdriver end to remove the 5 mm screw that secures the SSD.
      Ask FixBot
    3. Acer Swift X N20C12 SSD (Solid State Drive) Replacement: step 5, image 1 of 1
      • Gently remove the SSD from the computer by pulling it straight out of its motherboard socket.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Hector
427 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 49
All Time: 488
