Acer Swift 3 2022 Touchpad Replacement
  1. Acer Swift 3 2022 Touchpad Replacement, Bottom Cover: step 1, image 1 of 1
    • Be sure to power off the laptop before starting.
    • Flip the device over so the bottom panel is facing up.
    Ask FixBot
  2. Acer Swift 3 2022 Touchpad Replacement: step 2, image 1 of 2 Acer Swift 3 2022 Touchpad Replacement: step 2, image 2 of 2
    • Remove the eleven 5 mm screws from the back of the device using a TR6 Torx screwdriver.
    Ask FixBot
  3. Acer Swift 3 2022 Touchpad Replacement: step 3, image 1 of 1
    • Use the iFixit opening tool to pry open the back of the device.
    • Remove the bottom cover from the laptop.
    Ask FixBot
  4. Acer Swift 3 2022 Touchpad Replacement, Battery: step 4, image 1 of 2 Acer Swift 3 2022 Touchpad Replacement, Battery: step 4, image 2 of 2
    • Peel back the strip of black tape.
    Ask FixBot
  5. Acer Swift 3 2022 Touchpad Replacement: step 5, image 1 of 3 Acer Swift 3 2022 Touchpad Replacement: step 5, image 2 of 3 Acer Swift 3 2022 Touchpad Replacement: step 5, image 3 of 3
    • Unplug the group of wires by pulling the white plastic piece towards yourself.
    • Be careful, this piece can be easily damaged.
    Ask FixBot
  6. Acer Swift 3 2022 Touchpad Replacement: step 6, image 1 of 2 Acer Swift 3 2022 Touchpad Replacement: step 6, image 2 of 2
    • Remove the two 5 mm screws on the sides of the battery using a TR6 Torx screwdriver.
    Ask FixBot
  7. Acer Swift 3 2022 Touchpad Replacement: step 7, image 1 of 1
    • Remove battery.
    Ask FixBot
  8. Acer Swift 3 2022 Touchpad Replacement, Touchpad: step 8, image 1 of 1
    • Before disassembly, place a sheet of paper or cloth material between the touchpad and the screen.
    Ask FixBot
  9. Acer Swift 3 2022 Touchpad Replacement: step 9, image 1 of 2 Acer Swift 3 2022 Touchpad Replacement: step 9, image 2 of 2
    • Using the iFixit opening tool, flip up the black plastic retaining flap holding the white ribbon cable.
    • It's like popping open a coke can!
    Ask FixBot
  10. Acer Swift 3 2022 Touchpad Replacement: step 10, image 1 of 1
    • Pull the ribbon cable out.
    Ask FixBot
  11. Acer Swift 3 2022 Touchpad Replacement: step 11, image 1 of 2 Acer Swift 3 2022 Touchpad Replacement: step 11, image 2 of 2
    • Pull the black flap of film up to identify the two screws.
    • Remove the two 2 mm screws using a JIS #1 screwdriver.
    Ask FixBot
  12. Acer Swift 3 2022 Touchpad Replacement: step 12, image 1 of 1
    • Take out the touchpad.
    Ask FixBot
3 other people completed this guide.
Anna Miller
927 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 61
All Time: 1,848
