Acer Swift 3 2022 Fan Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
36
Past 30 Days:
123
All Time:
1,864
Comments: 2
2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Acer Swift 3 2022 Model Number: N20C12
If your Acer Swift 3 2022 is exhibiting a constant buzzing and humming noise and is overheating, use this guide to remedy those problems. This relatively easy procedure will have your computer as silent as when you first got it and no longer hot to the touch.
Before following this guide, try to remove dust and debris from the fan. This can be accomplished by using an ESD-safe brush or small dust blower and directing it at the fan located in the inner portion of the laptop. This should be completed before following through with the replacement. To view more information view our troubleshooting page.
Tools
    1. Acer Swift 3 2022 Fan Replacement, Bottom Cover: step 1, image 1 of 1
      • Be sure to power off the laptop before starting.
      • Flip the device over so the bottom panel is facing up.
      Ask FixBot
    2. Acer Swift 3 2022 Fan Replacement: step 2, image 1 of 2 Acer Swift 3 2022 Fan Replacement: step 2, image 2 of 2
      • Remove the eleven 5 mm screws from the back of the device using a TR6 Torx screwdriver.
      Ask FixBot
    3. Acer Swift 3 2022 Fan Replacement: step 3, image 1 of 1
      • Use the iFixit opening tool to pry open the back of the device.
      • Remove the bottom cover from the laptop.
      Ask FixBot
    1. Acer Swift 3 2022 Fan Replacement, How to Unplug the Battery: step 4, image 1 of 3 Acer Swift 3 2022 Fan Replacement, How to Unplug the Battery: step 4, image 2 of 3 Acer Swift 3 2022 Fan Replacement, How to Unplug the Battery: step 4, image 3 of 3
      • Peel back the strip of black tape.
      Ask FixBot
    2. Acer Swift 3 2022 Fan Replacement: step 5, image 1 of 2 Acer Swift 3 2022 Fan Replacement: step 5, image 2 of 2
      • Unplug the group of wires by pulling the white plastic piece towards yourself.
      • Be careful, this piece can be easily damaged.
      Ask FixBot
    1. Acer Swift 3 2022 Fan Replacement, Fan: step 6, image 1 of 2 Acer Swift 3 2022 Fan Replacement, Fan: step 6, image 2 of 2
      • Remove the two 4.5 mm screws from the fan using a Phillips #00 screwdriver.
      Ask FixBot
    2. Acer Swift 3 2022 Fan Replacement: step 7, image 1 of 2 Acer Swift 3 2022 Fan Replacement: step 7, image 2 of 2
      • Lift the metal clip using the iFixit opening tool to release the wire.
      Ask FixBot
    3. Acer Swift 3 2022 Fan Replacement: step 8, image 1 of 3 Acer Swift 3 2022 Fan Replacement: step 8, image 2 of 3 Acer Swift 3 2022 Fan Replacement: step 8, image 3 of 3
      • Unplug the wires by pulling gently on the white plastic.
      Ask FixBot
    4. Acer Swift 3 2022 Fan Replacement: step 9, image 1 of 1
      • Remove fan.
      Ask FixBot
Anna Miller
927 Reputation
6 Guides authored
2 Guide Comments
Correction. The fan should face the other way around - with the vent into the radiators of the heatsink. If the fan is placed incorrectly, overheating will occur.
Yehor - Reply Share
Yup, the flat bit of the fan goes to the outside of the laptop....... through the cooling grill, not the battery!
Sarah Cartwright - Reply Share
Past 24 Hours: 2
Past 7 Days: 36
Past 30 Days: 123
All Time: 1,864
