Acer Spin 5 N17W2 Trackpad Replacement
    1. Acer Spin 5 N17W2 Trackpad Replacement, Battery: step 1, image 1 of 2 Acer Spin 5 N17W2 Trackpad Replacement, Battery: step 1, image 2 of 2
      • Be sure to power off and unplug your device before you begin your repair.
      • Remove the twelve screws on the back cover using the Phillips #1 screwdriver.
      Ask FixBot
    2. Acer Spin 5 N17W2 Trackpad Replacement: step 2, image 1 of 1
      • Use an opening tool to pry the back cover open.
      Ask FixBot
    3. Acer Spin 5 N17W2 Trackpad Replacement: step 3, image 1 of 1
      • Remove two 4 mm screws at the two corners of the battery using the Phillips #1 screwdriver.
      Ask FixBot
    4. Acer Spin 5 N17W2 Trackpad Replacement: step 4, image 1 of 1
      • Carefully remove the three tapes on the battery.
      Ask FixBot
    5. Acer Spin 5 N17W2 Trackpad Replacement: step 5, image 1 of 1
      • Carefully slide the battery connector out of its motherboard socket.
      Ask FixBot
    6. Acer Spin 5 N17W2 Trackpad Replacement: step 6, image 1 of 1
      • Remove the battery from the device.
      Ask FixBot
    1. Acer Spin 5 N17W2 Trackpad Replacement, Trackpad: step 7, image 1 of 1
      • Using the blue spudger, pry the two black clips from the two ribbon cables on the bottom of the mouse pad.
      Ask FixBot
    2. Acer Spin 5 N17W2 Trackpad Replacement: step 8, image 1 of 1
      • Remove ribbon cables connected to the middle of the mouse pad.
      • Remove the adhesive tape from the left side of the mouse pad.
      Ask FixBot
    3. Acer Spin 5 N17W2 Trackpad Replacement: step 9, image 1 of 1
      • Using the phillips #1 screwdriver, remove the 4 screws securing the mouse pad.
      Ask FixBot
    4. Acer Spin 5 N17W2 Trackpad Replacement: step 10, image 1 of 1
      • Using your thumbs, push the mouse pad from the inside of the computer towards ur self and slide the mousepad out of the computer.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 21
All Time: 1,027
