Acer Spin 5 N17W2 SSD Replacement
    1. Acer Spin 5 N17W2 SSD Replacement, Battery: step 1, image 1 of 2 Acer Spin 5 N17W2 SSD Replacement, Battery: step 1, image 2 of 2
      • Be sure to power off and unplug your device before you begin your repair.
      • Remove the twelve screws on the back cover using the Phillips #1 screwdriver.
      Ask FixBot
    2. Acer Spin 5 N17W2 SSD Replacement: step 2, image 1 of 1
      • Use an opening tool to pry the back cover open.
      Ask FixBot
    3. Acer Spin 5 N17W2 SSD Replacement: step 3, image 1 of 1
      • Remove two 4 mm screws at the two corners of the battery using the Phillips #1 screwdriver.
      Ask FixBot
    4. Acer Spin 5 N17W2 SSD Replacement: step 4, image 1 of 1
      • Carefully remove the three tapes on the battery.
      Ask FixBot
    5. Acer Spin 5 N17W2 SSD Replacement: step 5, image 1 of 1
      • Carefully slide the battery connector out of its motherboard socket.
      Ask FixBot
    6. Acer Spin 5 N17W2 SSD Replacement: step 6, image 1 of 1
      • Remove the battery from the device.
      Ask FixBot
    1. Acer Spin 5 N17W2 SSD Replacement, SSD: step 7, image 1 of 1
      • Disconnect the SSD from the laptop.
      • At the time of guide creation, the device did not come equipped with the SSD.
      Ask FixBot
2 Guide Comments
That's not the RAM, that's the m.2 SSD slot. The RAM on this laptop is soldered to the mainboard and cannot be replaced/repaired.
Stephen Feger - Reply Share
Ok, so they changed this guide from a RAM change to an SSD change. Fine. One thing to point out is that the default m.2 drive for this laptop is a SATA based m.2, not a PCIe. Not sure if it can handle a PCIe m.2 drive.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 32
All Time: 2,819
