Up to 20% off select tools
Acer Predator Helios 300 RAM Replacement
Views: 6.4K
View statistics:
Past 24 Hours:
7
Past 7 Days:
44
Past 30 Days:
169
All Time:
6,381
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
This guide applies to the Acer Predator Helios 300 laptop.
Overheating and overuse may damage the memory card of the laptop. If your RAM in the Acer Predator Helios 300 is broken, please follow this guide to replace your RAM.
Before following this guide, please make sure to power off your laptop completely and disconnect from any external power source to avoid causing unnecessary and possible damage.
    1. Acer Predator Helios 300 RAM Replacement, RAM: step 1, image 1 of 3 Acer Predator Helios 300 RAM Replacement, RAM: step 1, image 2 of 3 Acer Predator Helios 300 RAM Replacement, RAM: step 1, image 3 of 3
      • Flip the laptop over so that the bottom is facing upward.
      • Find the memory card compartment.
      Ask FixBot
    2. Acer Predator Helios 300 RAM Replacement: step 2, image 1 of 2 Acer Predator Helios 300 RAM Replacement: step 2, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the 8 mm screw from the compartment.
      Ask FixBot
    3. Acer Predator Helios 300 RAM Replacement: step 3, image 1 of 3 Acer Predator Helios 300 RAM Replacement: step 3, image 2 of 3 Acer Predator Helios 300 RAM Replacement: step 3, image 3 of 3
      • Open the RAM cover from this corner using a finger or opening tool.
      Ask FixBot
    4. Acer Predator Helios 300 RAM Replacement: step 4, image 1 of 3 Acer Predator Helios 300 RAM Replacement: step 4, image 2 of 3 Acer Predator Helios 300 RAM Replacement: step 4, image 3 of 3
      • Bend the notches on either side of the RAM outwards.
      • Too much force may damage the metal notches so you should be very careful.
      Ask FixBot
    5. Acer Predator Helios 300 RAM Replacement: step 5, image 1 of 3 Acer Predator Helios 300 RAM Replacement: step 5, image 2 of 3 Acer Predator Helios 300 RAM Replacement: step 5, image 3 of 3
      • Remove the two RAM sticks.
      • The second card uses the same method.
      Ask FixBot
4 other people completed this guide.
Author
with
Chenkai Qian
267 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 44
Past 30 Days: 169
All Time: 6,381
