Acer Predator Helios 300 Battery Replacement
    1. Acer Predator Helios 300 Battery Replacement, Battery: step 1, image 1 of 3 Acer Predator Helios 300 Battery Replacement, Battery: step 1, image 2 of 3 Acer Predator Helios 300 Battery Replacement, Battery: step 1, image 3 of 3
      • Before you start make sure the laptop is grounded.
      • Make sure the laptop is powered off.
      • If the laptop is not turned off, there is a risk of electric shock when replacing the battery.
      • Close the cover of the laptop, then turn the laptop upside down so the back is facing up.
      Ask FixBot
    2. Acer Predator Helios 300 Battery Replacement: step 2, image 1 of 3 Acer Predator Helios 300 Battery Replacement: step 2, image 2 of 3 Acer Predator Helios 300 Battery Replacement: step 2, image 3 of 3
      • Remove all the screws from the back panel with a Phillips #0 screwdriver.
      • Remove the hard drive screw using a Phillips #0 screwdriver.
      • Use the panel tool to pop the storage hard disk open.
      Ask FixBot
    3. Acer Predator Helios 300 Battery Replacement: step 3, image 1 of 3 Acer Predator Helios 300 Battery Replacement: step 3, image 2 of 3 Acer Predator Helios 300 Battery Replacement: step 3, image 3 of 3
      • Remove the four screws mounted near the storage hard disk using a Phillips #0 screwdriver.
      • Disconnect the cable connected to the storage hard disk.
      Ask FixBot
    4. Acer Predator Helios 300 Battery Replacement: step 4, image 1 of 3 Acer Predator Helios 300 Battery Replacement: step 4, image 2 of 3 Acer Predator Helios 300 Battery Replacement: step 4, image 3 of 3
      • Use the panel tool to remove the back cover.
      • Slowly open the clips attached to the back cover, and store the cover safely.
      Ask FixBot
    5. Acer Predator Helios 300 Battery Replacement: step 5, image 1 of 3 Acer Predator Helios 300 Battery Replacement: step 5, image 2 of 3 Acer Predator Helios 300 Battery Replacement: step 5, image 3 of 3
      • Remove the tape holding the battery wires in.
      • Remove the two screws mounted next to the battery using a Phillips #0 screwdriver.
      • Disconnect the battery cable from the motherboard slowly.
      • Remove the old battery.
      Ask FixBot
    6. Acer Predator Helios 300 Battery Replacement: step 6, image 1 of 3 Acer Predator Helios 300 Battery Replacement: step 6, image 2 of 3 Acer Predator Helios 300 Battery Replacement: step 6, image 3 of 3
      • The battery is a Household Hazardous Waste, so be sure to follow your city's laws and dispose of them properly.
      • Connect the new battery connector to the motherboard and screw it back with the screwdriver.
      Ask FixBot
    7. Acer Predator Helios 300 Battery Replacement: step 7, image 1 of 2 Acer Predator Helios 300 Battery Replacement: step 7, image 2 of 2
      • Align the back cover with the laptop properly and click it with all the clips.
      Ask FixBot
    8. Acer Predator Helios 300 Battery Replacement: step 8, image 1 of 3 Acer Predator Helios 300 Battery Replacement: step 8, image 2 of 3 Acer Predator Helios 300 Battery Replacement: step 8, image 3 of 3
      • Insert the storage disk back in.
      • Connect it with the cable first and then fit it inside the missing space.
      • Fasten the remaining screws using a screwdriver.
      Ask FixBot
Finish Line
3 other people completed this guide.
Sidharth Rajeev
247 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 83
Past 30 Days: 345
All Time: 6,736
