Acer Predator Helios 300 (2020) Battery Replacement
    1. Acer Predator Helios 300 (2020) Battery Replacement, Battery: step 1, image 1 of 2 Acer Predator Helios 300 (2020) Battery Replacement, Battery: step 1, image 2 of 2
      • Turn off the laptop by holding the power button for 7 seconds.
      Ask FixBot
    2. Acer Predator Helios 300 (2020) Battery Replacement: step 2, image 1 of 2 Acer Predator Helios 300 (2020) Battery Replacement: step 2, image 2 of 2
      • Remove the eleven black 7.0 mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    3. Acer Predator Helios 300 (2020) Battery Replacement: step 3, image 1 of 2 Acer Predator Helios 300 (2020) Battery Replacement: step 3, image 2 of 2
      • Put your hands on the silver part of the chassis and pull up until you hear a snap.
      • Lift up the back panel and remove it from the device.
      Ask FixBot
    4. Acer Predator Helios 300 (2020) Battery Replacement: step 4, image 1 of 3 Acer Predator Helios 300 (2020) Battery Replacement: step 4, image 2 of 3 Acer Predator Helios 300 (2020) Battery Replacement: step 4, image 3 of 3
      • Remove the two 4.0 mm golden screws using the Phillips #00 screwdriver.
      Ask FixBot
    5. Acer Predator Helios 300 (2020) Battery Replacement: step 5, image 1 of 3 Acer Predator Helios 300 (2020) Battery Replacement: step 5, image 2 of 3 Acer Predator Helios 300 (2020) Battery Replacement: step 5, image 3 of 3
      • Disconnect the battery connector.
      Ask FixBot
    6. Acer Predator Helios 300 (2020) Battery Replacement: step 6, image 1 of 1
      • Remove the battery from the laptop.
      Ask FixBot
For optimal performance, after completing this guide, calibrate your newly installed battery.
8 other people completed this guide.
Steven Yuen
349 Reputation
1 Guide authored
1 Guide Comment
You're awesome, full stop. Thanks for this ridiculously easy to follow guide. Publishing guides should be your job.
[deleted] - Reply Share
Past 24 Hours: 7
Past 7 Days: 55
Past 30 Days: 150
All Time: 17,572
