Acer Predator 17 G9-791 Service Panel Replacement
    1. Acer Predator 17 G9-791 Service Panel Replacement, Service Panel: step 1, image 1 of 1
      • The service panel can be located on the bottom of the device. It is shown here as the panel located in the middle of the device, going from the upper vents to the bottom of the device.
      Ask FixBot
    2. Acer Predator 17 G9-791 Service Panel Replacement: step 2, image 1 of 2 Acer Predator 17 G9-791 Service Panel Replacement: step 2, image 2 of 2
      • Loosen the two Phillips #0 screws.
      • Pull up slightly on the top of the panel to help fully separate the screws from the rest of the device.
      Ask FixBot
    3. Acer Predator 17 G9-791 Service Panel Replacement: step 3, image 1 of 1
      • Continue pulling up on the panel to separate it from the laptop and remove it.
      Ask FixBot
Matthew Shane
376 Reputation
3 Guides authored
UMass Dartmouth, Team 5-1, Sinclaire Fall 2022 Member of UMass Dartmouth, Team 5-1, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S5G1
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 16
Past 30 Days: 56
All Time: 497
