Acer Nitro 5 AN515-57 RAM Replacement
    1. Acer Nitro 5 AN515-57 RAM Replacement, RAM: step 1, image 1 of 2 Acer Nitro 5 AN515-57 RAM Replacement, RAM: step 1, image 2 of 2
      • Shut-down your laptop and unplug the battery connection.
      • Remove any other device attached to the laptop.
      Ask FixBot
    2. Acer Nitro 5 AN515-57 RAM Replacement: step 2, image 1 of 1
      • Remove eleven screws from the bottom case of the laptop using a Phillips #00 screwdriver.
      Ask FixBot
    3. Acer Nitro 5 AN515-57 RAM Replacement: step 3, image 1 of 2 Acer Nitro 5 AN515-57 RAM Replacement: step 3, image 2 of 2
      • Slide an iFixit opening tool into the front lip of the laptop and slowly move your way around the chassis.
      • Make sure not to slide the tool too deep as it can damage the board.
      Ask FixBot
    4. Acer Nitro 5 AN515-57 RAM Replacement: step 4, image 1 of 2 Acer Nitro 5 AN515-57 RAM Replacement: step 4, image 2 of 2
      • Disconnect the battery by either using the iFixit opening tool or your fingers.
      Ask FixBot
    5. Acer Nitro 5 AN515-57 RAM Replacement: step 5, image 1 of 3 Acer Nitro 5 AN515-57 RAM Replacement: step 5, image 2 of 3 Acer Nitro 5 AN515-57 RAM Replacement: step 5, image 3 of 3
      • Use your fingers to pull the silver latches on either side of the RAM away from each other.
      • The RAM will pop up by a few centimeters.
      • Remove the RAM from the laptop.
      Ask FixBot
    6. Acer Nitro 5 AN515-57 RAM Replacement: step 6, image 1 of 1
      • Reconnect the battery pins
      • While reconnecting the battery, try not to touch the metal prongs.
      Ask FixBot
    7. Acer Nitro 5 AN515-57 RAM Replacement: step 7, image 1 of 2 Acer Nitro 5 AN515-57 RAM Replacement: step 7, image 2 of 2
      • Place the back panel on to your laptop and gently press on it until it snaps in place.
      • Screw the back panel back in.
      • When turning on your laptop the first time after installing new RAM, it may take the laptop a few minutes to turn on.
      Ask FixBot
Finish Line
5 other people completed this guide.
Hanzala Mir
266 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 59
Past 30 Days: 187
All Time: 9,910
