Acer Iconia W510 Battery Replacement
  1. Acer Iconia W510 Battery Replacement, Rear Cover: step 1, image 1 of 3 Acer Iconia W510 Battery Replacement, Rear Cover: step 1, image 2 of 3 Acer Iconia W510 Battery Replacement, Rear Cover: step 1, image 3 of 3
    • Carefully insert your metal pry tool between the back cover and the frame at an angle as shown.
    • Give the tool a twist to the left to start separating the clips.
    • Work your way to the corner, prying and twisting to pop the clips as you go.
    Ask FixBot
  2. Acer Iconia W510 Battery Replacement, Right Side: step 2, image 1 of 3 Acer Iconia W510 Battery Replacement, Right Side: step 2, image 2 of 3 Acer Iconia W510 Battery Replacement, Right Side: step 2, image 3 of 3
    • Insert an opening pick to make sure the clips don't close down again as you round the corner and start working on the right side of the tablet.
    • Continue as before, prying and twisting to release the catches.
    Ask FixBot
  3. Acer Iconia W510 Battery Replacement, Top Edge: step 3, image 1 of 2 Acer Iconia W510 Battery Replacement, Top Edge: step 3, image 2 of 2
    • Continue along the top edge as before
    • When you get to the corner, be careful not to insert the tool in the space below the power on symbol. There is a delicate clip there that is easy to break if you're prying with the tool. (Yes, I'm speaking from experience. Don't be me.)
    Ask FixBot
  4. Acer Iconia W510 Battery Replacement, Left Side: step 4, image 1 of 2 Acer Iconia W510 Battery Replacement, Left Side: step 4, image 2 of 2
    • Unclip the left side of the tablet.
    Ask FixBot
  5. Acer Iconia W510 Battery Replacement, Bottom Edge: step 5, image 1 of 2 Acer Iconia W510 Battery Replacement, Bottom Edge: step 5, image 2 of 2
    • Back to the bottom side again, this little part by itself is a little finicky to get unclipped, just follow the same procedure as with the first one.
    • And finally the home stretch between the keyboard/power connector and the right hand guide pin, back to where you started.
    Ask FixBot
  6. Acer Iconia W510 Battery Replacement: step 6, image 1 of 1
    • The rear cover is removed.
    Ask FixBot
  7. Acer Iconia W510 Battery Replacement, Unplug the Tablet Battery: step 7, image 1 of 2 Acer Iconia W510 Battery Replacement, Unplug the Tablet Battery: step 7, image 2 of 2
    • Peel back the tape securing the battery connector.
    Ask FixBot
  8. Acer Iconia W510 Battery Replacement: step 8, image 1 of 2 Acer Iconia W510 Battery Replacement: step 8, image 2 of 2
    • Grasp the plug by the tabs on either side and pull it straight out from the connector.
    Ask FixBot
  9. Acer Iconia W510 Battery Replacement, Battery: step 9, image 1 of 3 Acer Iconia W510 Battery Replacement, Battery: step 9, image 2 of 3 Acer Iconia W510 Battery Replacement, Battery: step 9, image 3 of 3
    • Remove the tape on the right side of the battery securing it to the tray.
    Ask FixBot
  10. Acer Iconia W510 Battery Replacement: step 10, image 1 of 1
    • Note the position of three strips of adhesive holding the battery in place.
    Ask FixBot
  11. Acer Iconia W510 Battery Replacement: step 11, image 1 of 3 Acer Iconia W510 Battery Replacement: step 11, image 2 of 3 Acer Iconia W510 Battery Replacement: step 11, image 3 of 3
    • Using a flexible piece of plastic, slip it under the battery and use it to slice the first adhesive strip.
    • Leave it in place while slicing the remaining strips.
    Ask FixBot
  12. Acer Iconia W510 Battery Replacement: step 12, image 1 of 2 Acer Iconia W510 Battery Replacement: step 12, image 2 of 2
    • Do the same with the second piece of adhesive.
    • Leave the card in place again.
    Ask FixBot
  13. Acer Iconia W510 Battery Replacement: step 13, image 1 of 2 Acer Iconia W510 Battery Replacement: step 13, image 2 of 2
    • And finally, slice the third adhesive strip.
    Ask FixBot
  14. Acer Iconia W510 Battery Replacement: step 14, image 1 of 2 Acer Iconia W510 Battery Replacement: step 14, image 2 of 2
    • The battery can now be lifted out of the tablet.
    Ask FixBot
  15. Acer Iconia W510 Battery Replacement: step 15, image 1 of 1
    • The battery is now free.
    Ask FixBot
Jerry Wheeler
97,961 Reputation
92 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 50
All Time: 877
