Acer Iconia Tab A501 Wireless Adapter Replacement
    1. Acer Iconia Tab A501 Wireless Adapter Replacement, Back Cover: step 1, image 1 of 3 Acer Iconia Tab A501 Wireless Adapter Replacement, Back Cover: step 1, image 2 of 3 Acer Iconia Tab A501 Wireless Adapter Replacement, Back Cover: step 1, image 3 of 3
      • Turn off your device before opening it.
      • Use a plastic opening tool to carefully separate the back cover, starting at the volume buttons.
      • Continue separating the back cover along the short side closest to the camera and around the device.
      Ask FixBot
    2. Acer Iconia Tab A501 Wireless Adapter Replacement: step 2, image 1 of 1
      • When separated enough, a little more than halfway around the device, the back cover will be easy to take off.
      Ask FixBot
    1. Acer Iconia Tab A501 Wireless Adapter Replacement, Wireless Adapter: step 3, image 1 of 3 Acer Iconia Tab A501 Wireless Adapter Replacement, Wireless Adapter: step 3, image 2 of 3 Acer Iconia Tab A501 Wireless Adapter Replacement, Wireless Adapter: step 3, image 3 of 3
      Tool used on this step:
      $3.99
      Buy
      • In the next step, be careful not to squeeze too hard or scratch the motherboard.
      • Use the angled tweezers to disconnect the motherboard-battery cable from the white connector in the middle of the side opposite the docking port.
      Ask FixBot
    2. Acer Iconia Tab A501 Wireless Adapter Replacement: step 4, image 1 of 1
      • Remove all tape covering the wireless adapter.
      Ask FixBot
    3. Acer Iconia Tab A501 Wireless Adapter Replacement: step 5, image 1 of 3 Acer Iconia Tab A501 Wireless Adapter Replacement: step 5, image 2 of 3 Acer Iconia Tab A501 Wireless Adapter Replacement: step 5, image 3 of 3
      • Use the flat end of the standard Spudger to disconnect the two small rotatable connectors attached to the wireless adapter.
      Ask FixBot
    4. Acer Iconia Tab A501 Wireless Adapter Replacement: step 6, image 1 of 2 Acer Iconia Tab A501 Wireless Adapter Replacement: step 6, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the two 3.0 mm Philips head screws holding the adapter down.
      Ask FixBot
    5. Acer Iconia Tab A501 Wireless Adapter Replacement: step 7, image 1 of 2 Acer Iconia Tab A501 Wireless Adapter Replacement: step 7, image 2 of 2
      • Carefully slide the adapter out to remove it.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 51
All Time: 647
