Acer Iconia Tab A501 Display Replacement
    1. Acer Iconia Tab A501 Display Replacement, Back Cover: step 1, image 1 of 3 Acer Iconia Tab A501 Display Replacement, Back Cover: step 1, image 2 of 3 Acer Iconia Tab A501 Display Replacement, Back Cover: step 1, image 3 of 3
      • Turn off your device before opening it.
      • Use a plastic opening tool to carefully separate the back cover, starting at the volume buttons.
      • Continue separating the back cover along the short side closest to the camera and around the device.
      Ask FixBot
    2. Acer Iconia Tab A501 Display Replacement: step 2, image 1 of 1
      • When separated enough, a little more than halfway around the device, the back cover will be easy to take off.
      Ask FixBot
    1. Acer Iconia Tab A501 Display Replacement, Display: step 3, image 1 of 1
      • Remove all tape from the device.
      Ask FixBot
    2. Acer Iconia Tab A501 Display Replacement: step 4, image 1 of 3 Acer Iconia Tab A501 Display Replacement: step 4, image 2 of 3 Acer Iconia Tab A501 Display Replacement: step 4, image 3 of 3
      Tool used on this step:
      $3.99
      Buy
      • In the next step, be careful not to squeeze too hard or scratch the motherboard.
      • Use the angled tweezers to disconnect the motherboard-battery cable from the white connector in the middle of the side opposite the docking port.
      Ask FixBot
    3. Acer Iconia Tab A501 Display Replacement: step 5, image 1 of 3 Acer Iconia Tab A501 Display Replacement: step 5, image 2 of 3 Acer Iconia Tab A501 Display Replacement: step 5, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the four 4.0 mm Philips head screws connecting the battery to the motherboard.
      • Take out the battery.
      Ask FixBot
    4. Acer Iconia Tab A501 Display Replacement: step 6, image 1 of 3 Acer Iconia Tab A501 Display Replacement: step 6, image 2 of 3 Acer Iconia Tab A501 Display Replacement: step 6, image 3 of 3
      • Use the plastic opening tool to flip up the locking mechanism on the motherboard connected to the folded, white ribbon cable.
      • Remove the folded, white cable.
      Ask FixBot
    5. Acer Iconia Tab A501 Display Replacement: step 7, image 1 of 3 Acer Iconia Tab A501 Display Replacement: step 7, image 2 of 3 Acer Iconia Tab A501 Display Replacement: step 7, image 3 of 3
      • Use a Phillips #1 screwdriver to unscrew the three 3.0 mm Philips head screws holding the docking port in place.
      • Remove the docking port.
      Ask FixBot
    6. Acer Iconia Tab A501 Display Replacement: step 8, image 1 of 3 Acer Iconia Tab A501 Display Replacement: step 8, image 2 of 3 Acer Iconia Tab A501 Display Replacement: step 8, image 3 of 3
      • In this step, be careful not to squeeze too hard or scratch the motherboard.
      • Use the angled tweezers to disconnect the cable with red, white and green wires from the beige connector slightly in from the docking port.
      Ask FixBot
    7. Acer Iconia Tab A501 Display Replacement: step 9, image 1 of 3 Acer Iconia Tab A501 Display Replacement: step 9, image 2 of 3 Acer Iconia Tab A501 Display Replacement: step 9, image 3 of 3
      • Unscrew the 3.0 mm Phillips head screw on each speaker using a Phillips #1 screwdriver.
      • Unscrew the 4.0 mm Phillips head screw on each speaker using a Phillips #1 screwdriver.
      Ask FixBot
    8. Acer Iconia Tab A501 Display Replacement: step 10, image 1 of 2 Acer Iconia Tab A501 Display Replacement: step 10, image 2 of 2
      • Remove the speakers.
      Ask FixBot
    9. Acer Iconia Tab A501 Display Replacement: step 11, image 1 of 3 Acer Iconia Tab A501 Display Replacement: step 11, image 2 of 3 Acer Iconia Tab A501 Display Replacement: step 11, image 3 of 3
      • Use the plastic opening tool to flip up the locking mechanism on the motherboard connected to the straight, white ribbon cable.
      • Remove the straight, white ribbon cable.
      Ask FixBot
    10. Acer Iconia Tab A501 Display Replacement: step 12, image 1 of 3 Acer Iconia Tab A501 Display Replacement: step 12, image 2 of 3 Acer Iconia Tab A501 Display Replacement: step 12, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the two 4.0 mm Philips screws attaching the metal plate, USB board, and device.
      • Remove the metal plate.
      Ask FixBot
    11. Acer Iconia Tab A501 Display Replacement: step 13, image 1 of 3 Acer Iconia Tab A501 Display Replacement: step 13, image 2 of 3 Acer Iconia Tab A501 Display Replacement: step 13, image 3 of 3
      Halberd Spudger
      $2.99
      Buy
      Ask FixBot
    12. Acer Iconia Tab A501 Display Replacement: step 14, image 1 of 3 Acer Iconia Tab A501 Display Replacement: step 14, image 2 of 3 Acer Iconia Tab A501 Display Replacement: step 14, image 3 of 3
      • Use care in the next step.
      • Use the wide, flat end of the standard Spudger to disconnect the display connector from the large, metal port next to the battery space.
      Ask FixBot
    13. Acer Iconia Tab A501 Display Replacement: step 15, image 1 of 3 Acer Iconia Tab A501 Display Replacement: step 15, image 2 of 3 Acer Iconia Tab A501 Display Replacement: step 15, image 3 of 3
      • Use the flat end of the standard Spudger to disconnect the two small, rotatable connectors attached to the wireless adapter.
      Ask FixBot
    14. Acer Iconia Tab A501 Display Replacement: step 16, image 1 of 3 Acer Iconia Tab A501 Display Replacement: step 16, image 2 of 3 Acer Iconia Tab A501 Display Replacement: step 16, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the two 3.0 mm Philips head screws holding the adapter down.
      Ask FixBot
    15. Acer Iconia Tab A501 Display Replacement: step 17, image 1 of 2 Acer Iconia Tab A501 Display Replacement: step 17, image 2 of 2
      • Carefully slide the adapter out to remove it.
      Ask FixBot
    16. Acer Iconia Tab A501 Display Replacement: step 18, image 1 of 3 Acer Iconia Tab A501 Display Replacement: step 18, image 2 of 3 Acer Iconia Tab A501 Display Replacement: step 18, image 3 of 3
      • Use the wide end of the standard Spudger to take off the rotatable connector to the 3g antenna below the rear-facing camera.
      Ask FixBot
    17. Acer Iconia Tab A501 Display Replacement: step 19, image 1 of 3 Acer Iconia Tab A501 Display Replacement: step 19, image 2 of 3 Acer Iconia Tab A501 Display Replacement: step 19, image 3 of 3
      • Use the angled tweezers to disconnect the cable with red wires from the beige connector opposite the docking port.
      Ask FixBot
    18. Acer Iconia Tab A501 Display Replacement: step 20, image 1 of 3 Acer Iconia Tab A501 Display Replacement: step 20, image 2 of 3 Acer Iconia Tab A501 Display Replacement: step 20, image 3 of 3
      • The charging port may be taped from underneath and need a bit of force to take out.
      • Use the angled tweezers to remove the charging port.
      Ask FixBot
    19. Acer Iconia Tab A501 Display Replacement: step 21, image 1 of 3 Acer Iconia Tab A501 Display Replacement: step 21, image 2 of 3 Acer Iconia Tab A501 Display Replacement: step 21, image 3 of 3
      • Use the tweezers to remove the white touchscreen connector with multi-colored wires from the black port just below the power buttons on the motherboard.
      Ask FixBot
    20. Acer Iconia Tab A501 Display Replacement: step 22, image 1 of 3 Acer Iconia Tab A501 Display Replacement: step 22, image 2 of 3 Acer Iconia Tab A501 Display Replacement: step 22, image 3 of 3
      • Use the plastic opening tool to flip up the locking mechanism for the wide, white port for the thin, orange-brown touchscreen cable just above the charging port.
      • Remove the touchscreen board.
      Ask FixBot
    21. Acer Iconia Tab A501 Display Replacement: step 23, image 1 of 3 Acer Iconia Tab A501 Display Replacement: step 23, image 2 of 3 Acer Iconia Tab A501 Display Replacement: step 23, image 3 of 3
      • Use the angled tweezers to disconnect two microphone connectors, which are above the orange-brown touchscreen connector and next to the battery space.
      Ask FixBot
    22. Acer Iconia Tab A501 Display Replacement: step 24, image 1 of 3 Acer Iconia Tab A501 Display Replacement: step 24, image 2 of 3 Acer Iconia Tab A501 Display Replacement: step 24, image 3 of 3
      • Use the plastic opening tool to flip up the locking mechanism to the white front camera port just above the rear-facing camera.
      • Disconnect the camera cable from the motherboard.
      Ask FixBot
    23. Acer Iconia Tab A501 Display Replacement: step 25, image 1 of 2 Acer Iconia Tab A501 Display Replacement: step 25, image 2 of 2
      • Use a Phillips #1 screwdriver to unscrew the four 4.0 mm Phillips head screws holding the motherboard in place.
      Ask FixBot
    24. Acer Iconia Tab A501 Display Replacement: step 26, image 1 of 2 Acer Iconia Tab A501 Display Replacement: step 26, image 2 of 2
      • Remove the motherboard.
      Ask FixBot
    25. Acer Iconia Tab A501 Display Replacement: step 27, image 1 of 3 Acer Iconia Tab A501 Display Replacement: step 27, image 2 of 3 Acer Iconia Tab A501 Display Replacement: step 27, image 3 of 3
      • Remove the two microphones in the middle of the side opposite the docking port.
      Ask FixBot
    26. Acer Iconia Tab A501 Display Replacement: step 28, image 1 of 2 Acer Iconia Tab A501 Display Replacement: step 28, image 2 of 2
      • Use the Phillips #1 screwdriver to unscrew the 3.0 mm Phillips head screw holding the thin metal plate to the device near the Micro-HDMI port.
      • Use the Phillips #1 screwdriver to unscrew the 4.0 mm Phillips head screw near the orange-brown touchscreen cable.
      Ask FixBot
    27. Acer Iconia Tab A501 Display Replacement: step 29, image 1 of 2 Acer Iconia Tab A501 Display Replacement: step 29, image 2 of 2
      • Move all wires off of the thin, metal plate.
      Ask FixBot
    28. Acer Iconia Tab A501 Display Replacement: step 30, image 1 of 1
      Ask FixBot
    29. Acer Iconia Tab A501 Display Replacement: step 31, image 1 of 3 Acer Iconia Tab A501 Display Replacement: step 31, image 2 of 3 Acer Iconia Tab A501 Display Replacement: step 31, image 3 of 3
      • The antennae in the next step are attached with adhesive.
      • Remove the three antennae along the shorter sides of the device.
      Ask FixBot
    30. Acer Iconia Tab A501 Display Replacement: step 32, image 1 of 3 Acer Iconia Tab A501 Display Replacement: step 32, image 2 of 3 Acer Iconia Tab A501 Display Replacement: step 32, image 3 of 3
      • Carefully insert the Jimmy between the display and the glass to break the glue seal.
      • Move the Jimmy all the way around the device.
      Ask FixBot
    31. Acer Iconia Tab A501 Display Replacement: step 33, image 1 of 3 Acer Iconia Tab A501 Display Replacement: step 33, image 2 of 3 Acer Iconia Tab A501 Display Replacement: step 33, image 3 of 3
      • Continue moving the Jimmy around the device until the glue no longer holds the display in place.
      • Remove the display.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 28
All Time: 642
