Acer Iconia Tab A501 Battery Replacement
  1. Acer Iconia Tab A501 Battery Replacement, Back Cover: step 1, image 1 of 3 Acer Iconia Tab A501 Battery Replacement, Back Cover: step 1, image 2 of 3 Acer Iconia Tab A501 Battery Replacement, Back Cover: step 1, image 3 of 3
    • Turn off your device before opening it.
    • Use a plastic opening tool to carefully separate the back cover, starting at the volume buttons.
    • Continue separating the back cover along the short side closest to the camera and around the device.
    Ask FixBot
  2. Acer Iconia Tab A501 Battery Replacement: step 2, image 1 of 1
    • When separated enough, a little more than halfway around the device, the back cover will be easy to take off.
    Ask FixBot
  3. Acer Iconia Tab A501 Battery Replacement, Battery: step 3, image 1 of 1
    • Take off any tape covering the battery or black battery-motherboard cable.
    Ask FixBot
  4. Acer Iconia Tab A501 Battery Replacement: step 4, image 1 of 3 Acer Iconia Tab A501 Battery Replacement: step 4, image 2 of 3 Acer Iconia Tab A501 Battery Replacement: step 4, image 3 of 3
    Tool used on this step:
    $3.99
    Buy
    • In the next step, be careful not to squeeze too hard or scratch the motherboard.
    • Use the angled tweezers to disconnect the white motherboard-battery connector in the middle of the side opposite the docking port.
    Ask FixBot
  5. Acer Iconia Tab A501 Battery Replacement: step 5, image 1 of 2 Acer Iconia Tab A501 Battery Replacement: step 5, image 2 of 2
    • Use a Phillips #1 screwdriver to remove the four 4.0 mm Philips head screws connecting the battery to the motherboard.
    Ask FixBot
  6. Acer Iconia Tab A501 Battery Replacement: step 6, image 1 of 1
    • Take out the battery.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 40
All Time: 870
