Acer Iconia Tab A500 Battery Replacement
    1. Acer Iconia Tab A500 Battery Replacement, Back Case: step 1, image 1 of 1
      • To start, gently separate one corner of the case using the black spudger.
      Ask FixBot
    2. Acer Iconia Tab A500 Battery Replacement: step 2, image 1 of 1
      • Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
      Ask FixBot
    1. Acer Iconia Tab A500 Battery Replacement, Battery: step 3, image 1 of 1
      • Remove the 5mm screws that are securing the battery to the rest of the tablet.
      • Use the Phillips #00 Screwdriver to remove the 5mm screws.
      Ask FixBot
    2. Acer Iconia Tab A500 Battery Replacement: step 4, image 1 of 1
      • Use the sharper end of the spudger to disconnect the battery from the mother board.
      • The battery connector will slide off.
      Ask FixBot
9 other people completed this guide.
Kyle Libby
1,006 Reputation
7 Guides authored
Cal Poly, Team 7-23, Regan Spring 2014 Member of Cal Poly, Team 7-23, Regan Spring 2014
CPSU-REGAN-S14S7G23
4 Members
108 Guides authored
2 Guide Comments
I just replaced my battery because it kept draining and the new battery started to charge but now it won’t charger at all so what can be wrong?
misscris0611 - Reply Share
Hi l have had my acer tablet for over 10 years and the acer iconiatab a500 as no been turned on for over 10 years and it is not cargering
Linda George - Reply Share
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 97
All Time: 12,202
