Acer Iconia One 8 Rear Camera Replacement
    1. Acer Iconia One 8 Rear Camera Replacement, Rear Camera: step 1, image 1 of 2 Acer Iconia One 8 Rear Camera Replacement, Rear Camera: step 1, image 2 of 2
      • The first step to replacing the rear camera on your Acer tablet is to remove the Back Panel. To do that, use your iFixit opening tool to pry open the device in the small crevice. Do this gently in order not to crack the screen on your tablet.
      Ask FixBot
    2. Acer Iconia One 8 Rear Camera Replacement: step 2, image 1 of 1
      • To remove the ZIF connector on the rear camera, gently use the flat end of your spudger to lift it up and free the rear camera.
      Ask FixBot
    3. Acer Iconia One 8 Rear Camera Replacement: step 3, image 1 of 1
      Tool used on this step:
      Buy
      • In order to gently remove the camera, grab the precision tweezers and carefully pull out the connector to remove the camera.
      Ask FixBot
1 Guide Comment
Hola, podrías hacer un post sobre cómo arreglar el toque, gracias.
chevas-carrillo - Reply Share
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 17
All Time: 586
