Acer Iconia One 8 Front Camera Replacement
    1. Acer Iconia One 8 Front Camera Replacement, Screen: step 1, image 1 of 2 Acer Iconia One 8 Front Camera Replacement, Screen: step 1, image 2 of 2
      • Begin by opening the back panel.
      • Wedge a plastic opening tool in between the front and back shell and gently separate.
      Ask FixBot
    2. Acer Iconia One 8 Front Camera Replacement: step 2, image 1 of 3 Acer Iconia One 8 Front Camera Replacement: step 2, image 2 of 3 Acer Iconia One 8 Front Camera Replacement: step 2, image 3 of 3
      • Peel back all pieces of tape indicated in picture.
      • There are three pieces of tape total (2 Black and 1 Silver).
      Ask FixBot
    3. Acer Iconia One 8 Front Camera Replacement: step 3, image 1 of 3 Acer Iconia One 8 Front Camera Replacement: step 3, image 2 of 3 Acer Iconia One 8 Front Camera Replacement: step 3, image 3 of 3
      • Disconnect all cables from the device.
      • There should be 5 total.
      Ask FixBot
    4. Acer Iconia One 8 Front Camera Replacement: step 4, image 1 of 3 Acer Iconia One 8 Front Camera Replacement: step 4, image 2 of 3 Acer Iconia One 8 Front Camera Replacement: step 4, image 3 of 3
      • Remove the nine 3mm screws using the Phillips #000 screwdriver.
      Ask FixBot
    5. Acer Iconia One 8 Front Camera Replacement: step 5, image 1 of 1
      • Remove and separate the back plating (top) from the glass screen (bottom).
      Ask FixBot
    1. Acer Iconia One 8 Front Camera Replacement, Motherboard: step 6, image 1 of 2 Acer Iconia One 8 Front Camera Replacement, Motherboard: step 6, image 2 of 2
      • Disconnect the metal tabs connecting the battery to the motherboard frame.
      Ask FixBot
    2. Acer Iconia One 8 Front Camera Replacement: step 7, image 1 of 2 Acer Iconia One 8 Front Camera Replacement: step 7, image 2 of 2
      • Disconnect the cable for the back camera.
      Ask FixBot
    3. Acer Iconia One 8 Front Camera Replacement: step 8, image 1 of 1
      • Flip the metal plating to reveal the front camera.
      Ask FixBot
    4. Acer Iconia One 8 Front Camera Replacement: step 9, image 1 of 2 Acer Iconia One 8 Front Camera Replacement: step 9, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to carefully remove the front camera from the adhesive on the motherboard.
      Ask FixBot
    5. Acer Iconia One 8 Front Camera Replacement: step 10, image 1 of 3 Acer Iconia One 8 Front Camera Replacement: step 10, image 2 of 3 Acer Iconia One 8 Front Camera Replacement: step 10, image 3 of 3
      • Flip the device back over.
      • Remove the motherboard from the metallic frame by feeding the back camera and front camera cable through the port.
      • Remove the front camera from the device.
      Ask FixBot
    1. Acer Iconia One 8 Front Camera Replacement, Front Camera: step 11, image 1 of 3 Acer Iconia One 8 Front Camera Replacement, Front Camera: step 11, image 2 of 3 Acer Iconia One 8 Front Camera Replacement, Front Camera: step 11, image 3 of 3
      • Separate the front-facing camera from the back camera.
      • The two cameras are connected by glue and can be pulled apart.
      Ask FixBot
Dustin Newland
343 Reputation
3 Guides authored
IUPUI, Team S1-G2, Stella Fall 2019 Member of IUPUI, Team S1-G2, Stella Fall 2019
IUPUI-STELLA-F19S1G2
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 18
All Time: 283
