Acer Iconia One 7 Motherboard Replacement
Views: 3.2K
View statistics:
Past 24 Hours:
Past 7 Days:
24
Past 30 Days:
96
All Time:
3,151
Comments: 1
1 comment on steps.
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Tablet motherboard's can wear out and sometimes they need to be replaced. This guide walks you through the necessary steps to replace it effectively. The motherboard embedded into this device requires specific tools and techniques to remove and replace it.
Tools
      • Reminder: Turn off device before you start opening your tablet.
      Ask FixBot
    1. Acer Iconia One 7 Motherboard Replacement: step 2, image 1 of 1
      • Begin at any side of the tablet.
      • With a plastic opening tool, begin taking apart the back cover from the tablet by working along the edges.
      • Use caution when prying the lid open to avoid damaging your tablet.
      Ask FixBot
    2. Acer Iconia One 7 Motherboard Replacement: step 3, image 1 of 1
      • Using a plastic opening tool, separate the back cover from the main device
      • Open each side continuously to ensure all sides have been separated,
      Ask FixBot
    3. Acer Iconia One 7 Motherboard Replacement: step 4, image 1 of 1
      • Turn tablet over.
      • Lay the tablet on a flat surface with the screen facing down. Locate the copper cover along the outside of the tablet.
      Ask FixBot
    4. Acer Iconia One 7 Motherboard Replacement: step 5, image 1 of 1
      • Carefully peel back the copper foil to reveal the motherboard.
      Ask FixBot
    5. Acer Iconia One 7 Motherboard Replacement: step 6, image 1 of 1
      • Peel tape back to expose connections.
      Ask FixBot
    6. Acer Iconia One 7 Motherboard Replacement: step 7, image 1 of 2 Acer Iconia One 7 Motherboard Replacement: step 7, image 2 of 2
      • There are several sets of wires connected to the motherboard as shown in the images. Carefully disconnect each set of wires.
      Ask FixBot
    7. Acer Iconia One 7 Motherboard Replacement: step 8, image 1 of 2 Acer Iconia One 7 Motherboard Replacement: step 8, image 2 of 2
      • Use a JIS screw bit #00 to remove screws around the motherboard using the provided image to locate each screw.
      Ask FixBot
    8. Acer Iconia One 7 Motherboard Replacement: step 9, image 1 of 1
      • Gently pull out motherboard.
      Ask FixBot
4 other people completed this guide.
Michael
519 Reputation
4 Guides authored
USF Tampa, Team 8-5, Eyestone Fall 2015 Member of USF Tampa, Team 8-5, Eyestone Fall 2015
USFT-EYESTONE-F15S8G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 24
Past 30 Days: 96
All Time: 3,151
