Acer Iconia B1-A71 LCD Display Replacement
Video Overview
  1. Acer Iconia B1-A71 LCD Display Replacement, Acer Iconia B1-A71 LCD Display Replacement: step 1, image 1 of 3 Acer Iconia B1-A71 LCD Display Replacement, Acer Iconia B1-A71 LCD Display Replacement: step 1, image 2 of 3 Acer Iconia B1-A71 LCD Display Replacement, Acer Iconia B1-A71 LCD Display Replacement: step 1, image 3 of 3
    • Switch-off the tablet.
    • If you can't switch it off, use the reset button to do this.
    • With a cutter and a plastic tool remove the back cover.
    • If you have a memory card inside, don't forget to remove it!
  2. Acer Iconia B1-A71 LCD Display Replacement: step 2, image 1 of 2 Acer Iconia B1-A71 LCD Display Replacement: step 2, image 2 of 2
    • First, disconnect the battery.
    • Now, disconnect the loudspeaker and remove the back cover.
    • Remove all scotch tapes and disconnect the touch screen flex cable...
    • LCD display flex cable,
    • the microphone,
    • and the WiFi and Bluetooth antennas flex cables.
  3. Acer Iconia B1-A71 LCD Display Replacement: step 3, image 1 of 3 Acer Iconia B1-A71 LCD Display Replacement: step 3, image 2 of 3 Acer Iconia B1-A71 LCD Display Replacement: step 3, image 3 of 3
    • Unscrew 5x screws and rmove the main board.
  4. Acer Iconia B1-A71 LCD Display Replacement: step 4, image 1 of 3 Acer Iconia B1-A71 LCD Display Replacement: step 4, image 2 of 3 Acer Iconia B1-A71 LCD Display Replacement: step 4, image 3 of 3
    • The battery is glued to the LCD display metal shield with a double sided adhesive tape.
    • Use plastic tools and carefully remove it.
    • Remove all tapes from the LCD display metal shield.
  5. Acer Iconia B1-A71 LCD Display Replacement: step 5, image 1 of 3 Acer Iconia B1-A71 LCD Display Replacement: step 5, image 2 of 3 Acer Iconia B1-A71 LCD Display Replacement: step 5, image 3 of 3
    • The LCD display is held by metal frame and some locking clips on it.
    • Use a cutter and a plastic tool to separate the LCD.
    • You have to work slowly so as not to break the display.
    • Now, install the new LCD display and reassemble the tablet.
    • Did you do it successfully?
    • Please SUBSCRIBE to my channel ツ
7 other people completed this guide.
ZFix
197,078 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
333 Members
1,478 Guides authored
1 Guide Comment
Iconia B1-A71 SNID 30313237615, MB KO, Battery out, display are good. I would like to use the display with Arduino shield, even without Touch control. There is a shield that can connect the flat of the display and maybe, but not essential, that of the touch?
Thanks.
Maurilio Fiorito - Reply Share
Past 24 Hours: 4
Past 7 Days: 11
Past 30 Days: 60
All Time: 11,435
