Acer Iconia B1-720 Rear Case Replacement
    1. Acer Iconia B1-720 Rear Case Replacement, Rear Case: step 1, image 1 of 3 Acer Iconia B1-720 Rear Case Replacement, Rear Case: step 1, image 2 of 3 Acer Iconia B1-720 Rear Case Replacement, Rear Case: step 1, image 3 of 3
      • Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
      Ask FixBot
    2. Acer Iconia B1-720 Rear Case Replacement: step 2, image 1 of 3 Acer Iconia B1-720 Rear Case Replacement: step 2, image 2 of 3 Acer Iconia B1-720 Rear Case Replacement: step 2, image 3 of 3
      • Slide the tool along until you have completely separated the rear cover.
      • If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
      Ask FixBot
    3. Acer Iconia B1-720 Rear Case Replacement: step 3, image 1 of 2 Acer Iconia B1-720 Rear Case Replacement: step 3, image 2 of 2
      • Once all the sides have been separated, you should be able to simply lift the cover off of the device.
      Ask FixBot
2 other people completed this guide.
Phillip Keavey
319 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 24
Past 30 Days: 95
All Time: 1,139
