Acer Iconia B1-720 Front Facing Camera Replacement
    1. Acer Iconia B1-720 Front Facing Camera Replacement, Rear Case: step 1, image 1 of 3 Acer Iconia B1-720 Front Facing Camera Replacement, Rear Case: step 1, image 2 of 3 Acer Iconia B1-720 Front Facing Camera Replacement, Rear Case: step 1, image 3 of 3
      • Insert a plastic opening tool into a gap near the charging port at the top of the device. Slide the tool in either direction along the device.
      Ask FixBot
    2. Acer Iconia B1-720 Front Facing Camera Replacement: step 2, image 1 of 3 Acer Iconia B1-720 Front Facing Camera Replacement: step 2, image 2 of 3 Acer Iconia B1-720 Front Facing Camera Replacement: step 2, image 3 of 3
      • Slide the tool along until you have completely separated the rear cover.
      • If needed, place the first tool in the gap created to hold this gap open and use a second tool to pry the remaining portion of the rear cover off.
      Ask FixBot
    3. Acer Iconia B1-720 Front Facing Camera Replacement: step 3, image 1 of 2 Acer Iconia B1-720 Front Facing Camera Replacement: step 3, image 2 of 2
      • Once all the sides have been separated, you should be able to simply lift the cover off of the device.
      Ask FixBot
    1. Acer Iconia B1-720 Front Facing Camera Replacement, Microphone/Speaker: step 4, image 1 of 3 Acer Iconia B1-720 Front Facing Camera Replacement, Microphone/Speaker: step 4, image 2 of 3 Acer Iconia B1-720 Front Facing Camera Replacement, Microphone/Speaker: step 4, image 3 of 3
      • Pry the speaker away from the device using the plastic opening tool. This may require a little force due to the adhesive that is on the device.(Battery is not shown in this picture for image
      • Tug gently on microphone to remove from slot.
      Ask FixBot
    2. Acer Iconia B1-720 Front Facing Camera Replacement: step 5, image 1 of 2 Acer Iconia B1-720 Front Facing Camera Replacement: step 5, image 2 of 2
      • Unwind the wire from the running channel.
      • To remove microphone, follow same steps.
      Ask FixBot
    3. Acer Iconia B1-720 Front Facing Camera Replacement: step 6, image 1 of 2 Acer Iconia B1-720 Front Facing Camera Replacement: step 6, image 2 of 2
      • Unplug connector from motherboard.
      • Follow same procedure to remove microphone.
      • Unplug the microphone in a similar fashion as with the speaker.
      Ask FixBot
    1. Acer Iconia B1-720 Front Facing Camera Replacement, Motherboard: step 7, image 1 of 3 Acer Iconia B1-720 Front Facing Camera Replacement, Motherboard: step 7, image 2 of 3 Acer Iconia B1-720 Front Facing Camera Replacement, Motherboard: step 7, image 3 of 3
      • Remove the yellow tape covering both ribbons in the two photos shown.
      Ask FixBot
    2. Acer Iconia B1-720 Front Facing Camera Replacement: step 8, image 1 of 2 Acer Iconia B1-720 Front Facing Camera Replacement: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to lift the small black locking tab off of the orange ribbon
      • Remove the orange ribbon from the lock using tweezers
      Ask FixBot
    3. Acer Iconia B1-720 Front Facing Camera Replacement: step 9, image 1 of 3 Acer Iconia B1-720 Front Facing Camera Replacement: step 9, image 2 of 3 Acer Iconia B1-720 Front Facing Camera Replacement: step 9, image 3 of 3
      • Use tweezers to remove rubber black wrap surrounding lock.
      • Use the tweezers to pull plastic tabs on each side of the black ribbon
      Ask FixBot
    4. Acer Iconia B1-720 Front Facing Camera Replacement: step 10, image 1 of 2 Acer Iconia B1-720 Front Facing Camera Replacement: step 10, image 2 of 2
      • Use tweezers to gently remove black ribbon from locking mechanism.
      Ask FixBot
    5. Acer Iconia B1-720 Front Facing Camera Replacement: step 11, image 1 of 3 Acer Iconia B1-720 Front Facing Camera Replacement: step 11, image 2 of 3 Acer Iconia B1-720 Front Facing Camera Replacement: step 11, image 3 of 3
      • Remove the 5 screws shown in the photograph
      • Lift the motherboard from the front panel of the device.
      Ask FixBot
    1. Acer Iconia B1-720 Front Facing Camera Replacement, Front Facing Camera: step 12, image 1 of 1
      • Flip the motherboard over so that you see the camera, micro usb port, and headphone jack.
      • The object marked in red is the camera.
      Ask FixBot
    2. Acer Iconia B1-720 Front Facing Camera Replacement: step 13, image 1 of 2 Acer Iconia B1-720 Front Facing Camera Replacement: step 13, image 2 of 2
      • Grab and gently lift the camera up from the motherboard until it becomes disconnected.
      Ask FixBot
Kervis Boston
479 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 12
Past 30 Days: 23
All Time: 632
