Acer Iconia B1-710 Tablet Camera Replacement
    1. Acer Iconia B1-710 Tablet Camera Replacement, Battery: step 1, image 1 of 3 Acer Iconia B1-710 Tablet Camera Replacement, Battery: step 1, image 2 of 3 Acer Iconia B1-710 Tablet Camera Replacement, Battery: step 1, image 3 of 3
      • Open the back cover by prying the casing off with an opening tool.
      • Be careful to not pull pieces apart aggressively. There is a wire that could break.
      Ask FixBot
    2. Acer Iconia B1-710 Tablet Camera Replacement: step 2, image 1 of 3 Acer Iconia B1-710 Tablet Camera Replacement: step 2, image 2 of 3 Acer Iconia B1-710 Tablet Camera Replacement: step 2, image 3 of 3
      • Unplug the battery from the motherboard.
      Ask FixBot
    3. Acer Iconia B1-710 Tablet Camera Replacement: step 3, image 1 of 1
      • Remove the battery.
      • The battery is lightly glued in, so there may be some difficulty getting it out.
      Ask FixBot
    1. Acer Iconia B1-710 Tablet Camera Replacement, Camera: step 4, image 1 of 2 Acer Iconia B1-710 Tablet Camera Replacement, Camera: step 4, image 2 of 2
      • Remove the five 3mm Phillips #000 screws. The location of the screws are shown in the above picture, circled in red.
      • Keep the removed screws in a safe place so they can be used later.
      Ask FixBot
    2. Acer Iconia B1-710 Tablet Camera Replacement: step 5, image 1 of 2 Acer Iconia B1-710 Tablet Camera Replacement: step 5, image 2 of 2
      • Unplug the LCD by lifting the LCD plug from the white board. The location of the LCD plug is shown in the above picture, circled in red.
      • If you are having difficulty removing the LCD plug, use a spudger to gently lift it.
      Ask FixBot
    3. Acer Iconia B1-710 Tablet Camera Replacement: step 6, image 1 of 2 Acer Iconia B1-710 Tablet Camera Replacement: step 6, image 2 of 2
      • Next, unplug the orange strip from the motherboard by gently lifting it. The location of the orange strip is shown in the above picture, circled in red.
      • The orange strip is delicate; be careful when unplugging it and make sure it doesn't tear.
      Ask FixBot
    4. Acer Iconia B1-710 Tablet Camera Replacement: step 7, image 1 of 3 Acer Iconia B1-710 Tablet Camera Replacement: step 7, image 2 of 3 Acer Iconia B1-710 Tablet Camera Replacement: step 7, image 3 of 3
      • Unplug the white wire, shown above, circled in red.
      • Unplug the black wire, shown above, circled in orange.
      Ask FixBot
    5. Acer Iconia B1-710 Tablet Camera Replacement: step 8, image 1 of 1
      • Gently, remove the motherboard by carefully lifting it.
      Ask FixBot
    6. Acer Iconia B1-710 Tablet Camera Replacement: step 9, image 1 of 3 Acer Iconia B1-710 Tablet Camera Replacement: step 9, image 2 of 3 Acer Iconia B1-710 Tablet Camera Replacement: step 9, image 3 of 3
      • Remove the camera from the motherboard with the spudger.
      • Be careful not to damage the camera plug; it is very delicate.
      Ask FixBot
To reassemble your device, follow the above instructions in reverse order.
Ryan Weber
358 Reputation
3 Guides authored
IUPUI, Team S3-G5, Baechle Spring 2017 Member of IUPUI, Team S3-G5, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G5
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 26
All Time: 649
