Acer Iconia B1-710 Screen Replacement
    1. Acer Iconia B1-710 Screen Replacement, Battery: step 1, image 1 of 3 Acer Iconia B1-710 Screen Replacement, Battery: step 1, image 2 of 3 Acer Iconia B1-710 Screen Replacement, Battery: step 1, image 3 of 3
      • Open the back cover by prying the casing off with an opening tool.
      • Be careful to not pull pieces apart aggressively. There is a wire that could break.
      Ask FixBot
    2. Acer Iconia B1-710 Screen Replacement: step 2, image 1 of 3 Acer Iconia B1-710 Screen Replacement: step 2, image 2 of 3 Acer Iconia B1-710 Screen Replacement: step 2, image 3 of 3
      • Unplug the battery from the motherboard.
      Ask FixBot
    3. Acer Iconia B1-710 Screen Replacement: step 3, image 1 of 1
      • Remove the battery.
      • The battery is lightly glued in, so there may be some difficulty getting it out.
      Ask FixBot
    1. Acer Iconia B1-710 Screen Replacement, Screen: step 4, image 1 of 2 Acer Iconia B1-710 Screen Replacement, Screen: step 4, image 2 of 2
      • Unscrew all five 3 mm #000 Phillips screws.
      Ask FixBot
    2. Acer Iconia B1-710 Screen Replacement: step 5, image 1 of 2 Acer Iconia B1-710 Screen Replacement: step 5, image 2 of 2
      • Unplug the LCD ribbon.
      Ask FixBot
    3. Acer Iconia B1-710 Screen Replacement: step 6, image 1 of 2 Acer Iconia B1-710 Screen Replacement: step 6, image 2 of 2
      • Unplug the orange ribbon.
      Ask FixBot
    4. Acer Iconia B1-710 Screen Replacement: step 7, image 1 of 3 Acer Iconia B1-710 Screen Replacement: step 7, image 2 of 3 Acer Iconia B1-710 Screen Replacement: step 7, image 3 of 3
      • Unplug the white wire from the motherboard.
      • Unplug the black wire from the motherboard.
      Ask FixBot
    5. Acer Iconia B1-710 Screen Replacement: step 8, image 1 of 1
      • Pull the motherboard off of the tablet.
      Ask FixBot
    6. Acer Iconia B1-710 Screen Replacement: step 9, image 1 of 1
      • Use a blow dryer to melt the glue holding the LCD display in place.
      • Patience is key. It will take a few minutes to melt the glue.
      Ask FixBot
    7. Acer Iconia B1-710 Screen Replacement: step 10, image 1 of 3 Acer Iconia B1-710 Screen Replacement: step 10, image 2 of 3 Acer Iconia B1-710 Screen Replacement: step 10, image 3 of 3
      • Peel the LCD display.
      • This piece is fragile and needs to be peeled with care.
      • Parts may be hot.
      Ask FixBot
    8. Acer Iconia B1-710 Screen Replacement: step 11, image 1 of 1
      • Use a blow dryer to melt the glue from the thin metal frame.
      • This piece is metal and will become hot during this process.
      Ask FixBot
    9. Acer Iconia B1-710 Screen Replacement: step 12, image 1 of 2 Acer Iconia B1-710 Screen Replacement: step 12, image 2 of 2
      • Peel off the thin metal frame.
      • Be careful not to bend the frame as it is very thin.
      Ask FixBot
    10. Acer Iconia B1-710 Screen Replacement: step 13, image 1 of 1
      • Use a blow dryer to melt the glue between the metal frame and the screen.
      • The frame will get hot.
      Ask FixBot
    11. Acer Iconia B1-710 Screen Replacement: step 14, image 1 of 2 Acer Iconia B1-710 Screen Replacement: step 14, image 2 of 2
      • Peel the frame from the screen.
      • Be careful when peeling the screen or it may sustain further damage.
      Ask FixBot
Ryan Weber
358 Reputation
3 Guides authored
IUPUI, Team S3-G5, Baechle Spring 2017 Member of IUPUI, Team S3-G5, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G5
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 35
All Time: 1,360
