Acer Iconia A110 Motherboard Replacement
    1. Acer Iconia A110 Motherboard Replacement, Battery: step 1, image 1 of 2 Acer Iconia A110 Motherboard Replacement, Battery: step 1, image 2 of 2
      • Before taking apart your tablet, make sure the device is powered off.
      • Pry open the right side of case with the plastic opening tool. If necessary, keep a tool lodged into the side to keep the case from closing.
      • During this process, the volume button and/or power button may fall out.
      Ask FixBot
    2. Acer Iconia A110 Motherboard Replacement: step 2, image 1 of 3 Acer Iconia A110 Motherboard Replacement: step 2, image 2 of 3 Acer Iconia A110 Motherboard Replacement: step 2, image 3 of 3
      • Pry open the left side of the case with a plastic opening tool. The backside of the tablet should now separate completely from the front.
      Ask FixBot
    3. Acer Iconia A110 Motherboard Replacement: step 3, image 1 of 3 Acer Iconia A110 Motherboard Replacement: step 3, image 2 of 3 Acer Iconia A110 Motherboard Replacement: step 3, image 3 of 3
      • Using the plastic opening tool and spudger, carefully pry up the battery from the case.
      • You should hear the adhesive ripping as you do this.
      • Once the battery is no longer adhered to the case, detach the dongle that connects the battery to the motherboard.
      Ask FixBot
    1. Acer Iconia A110 Motherboard Replacement, Speaker: step 4, image 1 of 2 Acer Iconia A110 Motherboard Replacement, Speaker: step 4, image 2 of 2
      • With the Phillips #00 screwdriver, remove the following screws securing the motherboard to the back panel:
      • Two 2.0 mm screws (with the bigger head)
      • Four 2.5 mm screws (with the smaller head)
      Ask FixBot
    2. Acer Iconia A110 Motherboard Replacement: step 5, image 1 of 2 Acer Iconia A110 Motherboard Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • On the top right side of the motherboard, is the vibration motor. With tweezers, carefully pull the vibration motor out from underneath the motherboard.
      • The vibration motor is still connected to the motherboard by a small wire connection, so be careful not to rip the wire out.
      • With your fingers, carefully disconnect the cable securing the vibration motor to the motherboard. Set aside.
      Ask FixBot
    3. Acer Iconia A110 Motherboard Replacement: step 6, image 1 of 2 Acer Iconia A110 Motherboard Replacement: step 6, image 2 of 2
      • The speaker located on the top of the motherboard should easily slide out. Take note that there is still a wire connected, so do so carefully.
      • With your fingers, slowly pull out the wire connecting the speaker to the motherboard.
      Ask FixBot
    1. Acer Iconia A110 Motherboard Replacement, Motherboard: step 7, image 1 of 3 Acer Iconia A110 Motherboard Replacement, Motherboard: step 7, image 2 of 3 Acer Iconia A110 Motherboard Replacement, Motherboard: step 7, image 3 of 3
      Buy
      • The next step is to pull out the ribbon cables connected to the motherboard.
      • Each ribbon cable has a sticker covering it; peel it off with tweezers.
      • Use tweezers to pull out the ribbon cable.
      • Make sure to pull the ribbon cable horizontally, not vertically to avoid tearing the ribbon
      Ask FixBot
    2. Acer Iconia A110 Motherboard Replacement: step 8, image 1 of 3 Acer Iconia A110 Motherboard Replacement: step 8, image 2 of 3 Acer Iconia A110 Motherboard Replacement: step 8, image 3 of 3
      • After all ribbon cables are disconnected,move them out of the way, and the motherboard should fall out easily.
      Ask FixBot
Andrea
757 Reputation
5 Guides authored
Cal Poly, Team 3-42, Maness Spring 2014 Member of Cal Poly, Team 3-42, Maness Spring 2014
CPSU-MANESS-S14S3G42
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 19
Past 30 Days: 68
All Time: 2,629
