Acer Iconia A110 Battery Replacement
    1. Acer Iconia A110 Battery Replacement, Battery: step 1, image 1 of 2 Acer Iconia A110 Battery Replacement, Battery: step 1, image 2 of 2
      • Before taking apart your tablet, make sure the device is powered off.
      • Pry open the right side of case with the plastic opening tool. If necessary, keep a tool lodged into the side to keep the case from closing.
      • During this process, the volume button and/or power button may fall out.
      Ask FixBot
    2. Acer Iconia A110 Battery Replacement: step 2, image 1 of 3 Acer Iconia A110 Battery Replacement: step 2, image 2 of 3 Acer Iconia A110 Battery Replacement: step 2, image 3 of 3
      • Pry open the left side of the case with a plastic opening tool. The backside of the tablet should now separate completely from the front.
      Ask FixBot
    3. Acer Iconia A110 Battery Replacement: step 3, image 1 of 3 Acer Iconia A110 Battery Replacement: step 3, image 2 of 3 Acer Iconia A110 Battery Replacement: step 3, image 3 of 3
      • Using the plastic opening tool and spudger, carefully pry up the battery from the case.
      • You should hear the adhesive ripping as you do this.
      • Once the battery is no longer adhered to the case, detach the dongle that connects the battery to the motherboard.
      Ask FixBot
3 other people completed this guide.
Andrea
757 Reputation
5 Guides authored
Cal Poly, Team 3-42, Maness Spring 2014 Member of Cal Poly, Team 3-42, Maness Spring 2014
CPSU-MANESS-S14S3G42
4 Members
60 Guides authored
1 Guide Comment
Where can you purchase the battery for acer iconia tab a110?
redd4167 - Reply Share
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 52
All Time: 11,770
