Up to 20% off select tools
Acer Iconia A100 Light Sensor Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
86
All Time:
629
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this step-by-step guide to replace the Light Sensor Module on your Acer Iconia Tab A100.
    1. Acer Iconia A100 Light Sensor  Replacement, Battery: step 1, image 1 of 1
      • Start at any side of the tablet.
      • Begin to take apart the tablet with a plastic opening tool along the sides of the tablet.
      • Work your way around the tablet.
      • There are four side pieces in total.
      Ask FixBot
    2. Acer Iconia A100 Light Sensor  Replacement: step 2, image 1 of 1
      • Remove the five 4 mm screws from the edges of the tablet with a Phillips #00 screwdriver.
      Ask FixBot
    3. Acer Iconia A100 Light Sensor  Replacement: step 3, image 1 of 1
      • Carefully separate the back piece from the device using a plastic opening tool.
      • Remember to open along the entire perimeter of the tablet.
      Ask FixBot
    4. Acer Iconia A100 Light Sensor  Replacement: step 4, image 1 of 1
      • Turn the tablet over so that the battery is facing upwards.
      • Remove the four 4mm screws located around the battery.
      Ask FixBot
    5. Acer Iconia A100 Light Sensor  Replacement: step 5, image 1 of 2 Acer Iconia A100 Light Sensor  Replacement: step 5, image 2 of 2
      • Use the tip of a plastic spudger or opening tool to gently push the connector head out of its socket.
      • Use your fingers or the flat edge of a plastic opening tool to lift the battery up and off of the device.
      • Be sure to not have any water around the device while removing the battery.
      • Be sure to be cautious while removing the battery and remove carefully; avoid ripping the wires attached to the battery.
      Ask FixBot
    1. Acer Iconia A100 Light Sensor  Replacement, I/O Board: step 6, image 1 of 1
      • Gently peel off any tape securing the FPC to the main plate.
      Ask FixBot
    2. Acer Iconia A100 Light Sensor  Replacement: step 7, image 1 of 3 Acer Iconia A100 Light Sensor  Replacement: step 7, image 2 of 3 Acer Iconia A100 Light Sensor  Replacement: step 7, image 3 of 3
      • Locate the two connectors at each end of the FPC.
      • Use the flat edge of a spudger tool or your fingernail to gently pry each connector straight upwards out of its socket, then remove the FPC cable from the unit.
      • While a metal spudger tool is shown here, it is best to use a plastic spudger / opening tool when possible, and only use a metal spudger as a last resort!
      • You should now see the yellow-colored strip on the metal base marking the location of the FPC
      Ask FixBot
    3. Acer Iconia A100 Light Sensor  Replacement: step 8, image 1 of 1
      • Locate the L-shaped I/O Board.
      • Locate the gray 3G Antenna wire.
      • If the gray 3G Antenna wire is connected to your I/O Board, disconnect it. If for some reason the 3G Antenna wire is already disconnected from the I/O Board (as it was in this device) simply lift it out of the way.
      Ask FixBot
    4. Acer Iconia A100 Light Sensor  Replacement: step 9, image 1 of 2 Acer Iconia A100 Light Sensor  Replacement: step 9, image 2 of 2
      • Locate the microphone cable.
      • You should be able to gently pull it out of its socket using only your fingers.
      • The spudger is used in the photo merely to hold up / identify the disconnected mic cable head.
      Ask FixBot
    5. Acer Iconia A100 Light Sensor  Replacement: step 10, image 1 of 3 Acer Iconia A100 Light Sensor  Replacement: step 10, image 2 of 3 Acer Iconia A100 Light Sensor  Replacement: step 10, image 3 of 3
      • Locate the light sensor connector.
      • Use the tip of a spudger or your fingernail to lift up and flip the small retaining flap on the connector. The light sensor ribbon cable should now be free, so simply pull it out.
      • This is a ZIF (zero insertion force) connector, which requires no force to remove / plug in the connector.
      • Please make sure you lift up on the small retaining flap on the connector, not the connector itself!
      • Use a Phillips #00 screwdriver to unscrew the single 3.0mm Phillips screw next to the light sensor connector.
      Ask FixBot
    6. Acer Iconia A100 Light Sensor  Replacement: step 11, image 1 of 2 Acer Iconia A100 Light Sensor  Replacement: step 11, image 2 of 2
      • Carefully lift the I/O Board off the device.
      Ask FixBot
    1. Acer Iconia A100 Light Sensor  Replacement, Light Sensor: step 12, image 1 of 2 Acer Iconia A100 Light Sensor  Replacement, Light Sensor: step 12, image 2 of 2
      • To remove the light sensor, use the flat edge of a spudger, plastic opening tool, or your fingernail to gently pry the top of the square connector straight up and out of its socket.
      Ask FixBot
Author
with
Bree Abernathy
341 Reputation
3 Guides authored
IUPUI, Team S1-G4, Harley Spring 2017 Member of IUPUI, Team S1-G4, Harley Spring 2017
IUPUI-HARLEY-S17S1G4
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 86
All Time: 629
