Acer Iconia A1-830 Front Facing Camera Replacement
    1. Acer Iconia A1-830 Front Facing Camera Replacement, Disassembling Acer Iconia A1-830 Back Panel: step 1, image 1 of 2 Acer Iconia A1-830 Front Facing Camera Replacement, Disassembling Acer Iconia A1-830 Back Panel: step 1, image 2 of 2
      • Prepare your working space. The ideal work space has a flat, level surface that is clean and well lit.
      • Shut down your Acer Iconia A1-830.
      • Remove any cables or exterior covers from your tablet.
      • Place it on your work space, with the screen facing up.
      Ask FixBot
    2. Acer Iconia A1-830 Front Facing Camera Replacement: step 2, image 1 of 2 Acer Iconia A1-830 Front Facing Camera Replacement: step 2, image 2 of 2
      • Wedge the plastic opening tool into the tiny gap between the white plastic front bezel and the aluminum rear panel.
      • Do not try to pry apart the top edge on the front side near the front-facing camera.
      Ask FixBot
    1. Acer Iconia A1-830 Front Facing Camera Replacement, Battery: step 3, image 1 of 2 Acer Iconia A1-830 Front Facing Camera Replacement, Battery: step 3, image 2 of 2
      • Remove the small clear plastic cover on top of the battery cable with the nylon or metal spudger.
      Ask FixBot
    2. Acer Iconia A1-830 Front Facing Camera Replacement: step 4, image 1 of 1
      • Remove the battery cable by lifting it up with the pointy end of the black nylon spudger.
      Ask FixBot
    3. Acer Iconia A1-830 Front Facing Camera Replacement: step 5, image 1 of 2 Acer Iconia A1-830 Front Facing Camera Replacement: step 5, image 2 of 2
      • Un-stick the battery from the metal plate using the black nylon spudger.
      • Be careful not to puncture the battery while removing it.
      Ask FixBot
    1. Acer Iconia A1-830 Front Facing Camera Replacement, Front Facing Camera: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Peel off the piece of black tape covering the front facing camera ribbon cable.
      • Do this by holding down the ribbon cable and peeling off the tape with the metal tweezers.
      Ask FixBot
    2. Acer Iconia A1-830 Front Facing Camera Replacement: step 7, image 1 of 1
      • Peel off the piece of black tape covering the front facing camera ribbon cable connector.
      Ask FixBot
    3. Acer Iconia A1-830 Front Facing Camera Replacement: step 8, image 1 of 3 Acer Iconia A1-830 Front Facing Camera Replacement: step 8, image 2 of 3 Acer Iconia A1-830 Front Facing Camera Replacement: step 8, image 3 of 3
      • Lift up the small white lever to release the ribbon cable.
      • Pull out the ribbon cable from the connector with the metal tweezers.
      • Lift out the front facing camera from the plastic frame.
      Ask FixBot
Brendan Coveney
593 Reputation
3 Guides authored
UMass Dartmouth, Team 4-6, Catania Fall 2015 Member of UMass Dartmouth, Team 4-6, Catania Fall 2015
UMASSD-CATANIA-F15S4G6
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 93
All Time: 1,052
