Acer Iconia A1-830 Battery Replacement
    1. Acer Iconia A1-830 Battery Replacement, Disassembling Acer Iconia A1-830 Back Panel: step 1, image 1 of 2 Acer Iconia A1-830 Battery Replacement, Disassembling Acer Iconia A1-830 Back Panel: step 1, image 2 of 2
      • Prepare your working space. The ideal work space has a flat, level surface that is clean and well lit.
      • Shut down your Acer Iconia A1-830.
      • Remove any cables or exterior covers from your tablet.
      • Place it on your work space, with the screen facing up.
      Ask FixBot
    2. Acer Iconia A1-830 Battery Replacement: step 2, image 1 of 2 Acer Iconia A1-830 Battery Replacement: step 2, image 2 of 2
      • Wedge the plastic opening tool into the tiny gap between the white plastic front bezel and the aluminum rear panel.
      • Do not try to pry apart the top edge on the front side near the front-facing camera.
      Ask FixBot
    1. Acer Iconia A1-830 Battery Replacement, Battery: step 3, image 1 of 2 Acer Iconia A1-830 Battery Replacement, Battery: step 3, image 2 of 2
      • Remove the small clear plastic cover on top of the battery cable with the nylon or metal spudger.
      Ask FixBot
    2. Acer Iconia A1-830 Battery Replacement: step 4, image 1 of 1
      • Remove the battery cable by lifting it up with the pointy end of the black nylon spudger.
      Ask FixBot
    3. Acer Iconia A1-830 Battery Replacement: step 5, image 1 of 2 Acer Iconia A1-830 Battery Replacement: step 5, image 2 of 2
      • Un-stick the battery from the metal plate using the black nylon spudger.
      • Be careful not to puncture the battery while removing it.
      Ask FixBot
5 other people completed this guide.
Matt Champagne
458 Reputation
2 Guides authored
UMass Dartmouth, Team 4-6, Catania Fall 2015 Member of UMass Dartmouth, Team 4-6, Catania Fall 2015
UMASSD-CATANIA-F15S4G6
3 Members
60 Guides authored
2 Guide Comments
thnks is goood
mo7tarif1997 - Reply Share
Is it okay if the battery bends a slight bit when prying it off?
Doof - Reply Share
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 95
All Time: 9,775
