Acer Iconia A1-810 Screen Replacement
    1. Acer Iconia A1-810 Screen Replacement, Battery: step 1, image 1 of 1
      • Remove the back cover by lifting with a plastic opening tool, below the camera button slot.
      Ask FixBot
    2. Acer Iconia A1-810 Screen Replacement: step 2, image 1 of 1
      • Remove the black tape connecting the battery to the motherboard.
      Ask FixBot
    3. Acer Iconia A1-810 Screen Replacement: step 3, image 1 of 1
      • Pinch the sides of the white resistor to safely remove it without damaging it or yourself.
      Ask FixBot
    4. Acer Iconia A1-810 Screen Replacement: step 4, image 1 of 2 Acer Iconia A1-810 Screen Replacement: step 4, image 2 of 2
      • Remove battery from adhesive.
      Ask FixBot
    1. Acer Iconia A1-810 Screen Replacement, Motherboard: step 5, image 1 of 1
      • Use a Phillips #000 screwdriver to remove the screws around the perimeter of the motherboard.
      Ask FixBot
    2. Acer Iconia A1-810 Screen Replacement: step 6, image 1 of 2 Acer Iconia A1-810 Screen Replacement: step 6, image 2 of 2
      • Disconnect the resistor attached to the orange tab by sliding the tail out.
      • Pry open the orange tab near the top left corner.
      Ask FixBot
    3. Acer Iconia A1-810 Screen Replacement: step 7, image 1 of 3 Acer Iconia A1-810 Screen Replacement: step 7, image 2 of 3 Acer Iconia A1-810 Screen Replacement: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Disconnect all cords, wires, and resistors from the motherboard using tweezers.
      Ask FixBot
    4. Acer Iconia A1-810 Screen Replacement: step 8, image 1 of 3 Acer Iconia A1-810 Screen Replacement: step 8, image 2 of 3 Acer Iconia A1-810 Screen Replacement: step 8, image 3 of 3
      • Continue to disconnect all resistors attached from the motherboard, using tweezers.
      Ask FixBot
    5. Acer Iconia A1-810 Screen Replacement: step 9, image 1 of 1
      • Gently lift motherboard out.
      • The edges may be sharp.
      Ask FixBot
    1. Acer Iconia A1-810 Screen Replacement, Screen: step 10, image 1 of 3 Acer Iconia A1-810 Screen Replacement, Screen: step 10, image 2 of 3 Acer Iconia A1-810 Screen Replacement, Screen: step 10, image 3 of 3
      • Lift the three copper foils from the plate.
      Ask FixBot
    2. Acer Iconia A1-810 Screen Replacement: step 11, image 1 of 1
      • Add strips of tape to the sides of the device.
      Ask FixBot
    3. Acer Iconia A1-810 Screen Replacement: step 12, image 1 of 2 Acer Iconia A1-810 Screen Replacement: step 12, image 2 of 2
      • Wedge the Jimmy between the screen and body of the device and ease around the whole edge of the device.
      • A reasonable amount of force is necessary to wedge deep into the screen.
      • The screen will possibly crack more and the debris will be scattered.
      Ask FixBot
    4. Acer Iconia A1-810 Screen Replacement: step 13, image 1 of 3 Acer Iconia A1-810 Screen Replacement: step 13, image 2 of 3 Acer Iconia A1-810 Screen Replacement: step 13, image 3 of 3
      • While holding the side of the screen, press the metal plates behind the device to pop the screen out.
      Ask FixBot
15 other people completed this guide.
John
635 Reputation
3 Guides authored
UWT Liner: Group 3 Member of UWT Liner: Group 3
Community
5 Members
36 Guides authored
1 Guide Comment
Before starting to remove the screen, remove the strip of black tape stuck over the screen ribbon cable (right hand end in the last picture) carefully lift the connector lock on the old screen connector and remove the ribbon cable completely.
Fit this ribbon cable to the new display before fitting the screen and the feed it through the slot provided as you install.
Michael - Reply Share
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 29
All Time: 10,796
