Up to 20% off select tools
Acer Extensa 4420 RAM Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
11
Past 30 Days:
56
All Time:
418
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Easy
Community-Contributed Guide
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. Acer Extensa 4420 RAM Replacement, Battery: step 1, image 1 of 2 Acer Extensa 4420 RAM Replacement, Battery: step 1, image 2 of 2
      • First, make sure that the battery lock is turned off.
      • The battery lock makes it so the battery doesn't accidentally fall out of your computer while it is running.
      Ask FixBot
    2. Acer Extensa 4420 RAM Replacement: step 2, image 1 of 3 Acer Extensa 4420 RAM Replacement: step 2, image 2 of 3 Acer Extensa 4420 RAM Replacement: step 2, image 3 of 3
      • Then, slide the other battery lock while pulling the battery out.
      Ask FixBot
    1. Acer Extensa 4420 RAM Replacement, Back Panel: step 3, image 1 of 1
      Tool used on this step:
      $5.49
      Buy
      • Unscrew all five screws on the back panel with a Phillips #00 screwdriver
      • The screws will stay in the back panel, so when you remove it, you don't have to worry about organizing the screws.
      Ask FixBot
    2. Acer Extensa 4420 RAM Replacement: step 4, image 1 of 3 Acer Extensa 4420 RAM Replacement: step 4, image 2 of 3 Acer Extensa 4420 RAM Replacement: step 4, image 3 of 3
      Spudger
      $3.99
      Buy
      • Take a spudger and start to pry open the back panel. Finish prying it open with your hands.
      • Be extra careful and try not to break any clips in this process.
      Ask FixBot
    1. Acer Extensa 4420 RAM Replacement, RAM: step 5, image 1 of 3 Acer Extensa 4420 RAM Replacement, RAM: step 5, image 2 of 3 Acer Extensa 4420 RAM Replacement, RAM: step 5, image 3 of 3
      • Push the clips in red towards the outside. Doing so will release the RAM. Pull the RAM out.
      • Do this for both RAM modules
      Ask FixBot
Author
with
TheMasterG
1,460 Reputation
12 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 56
All Time: 418
