Up to 20% off select tools
Acer Extensa 4420 Keyboard Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
13
Past 30 Days:
70
All Time:
448
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 - 5 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
  • Spudger
    4.9
  • Phillips #000 Screwdriver
    4.9
    1. Acer Extensa 4420 Keyboard Replacement, Battery: step 1, image 1 of 2 Acer Extensa 4420 Keyboard Replacement, Battery: step 1, image 2 of 2
      • First, make sure that the battery lock is turned off.
      • The battery lock makes it so the battery doesn't accidentally fall out of your computer while it is running.
      Ask FixBot
    2. Acer Extensa 4420 Keyboard Replacement: step 2, image 1 of 3 Acer Extensa 4420 Keyboard Replacement: step 2, image 2 of 3 Acer Extensa 4420 Keyboard Replacement: step 2, image 3 of 3
      • Then, slide the other battery lock while pulling the battery out.
      Ask FixBot
    1. Acer Extensa 4420 Keyboard Replacement, Keyboard Cover: step 3, image 1 of 3 Acer Extensa 4420 Keyboard Replacement, Keyboard Cover: step 3, image 2 of 3 Acer Extensa 4420 Keyboard Replacement, Keyboard Cover: step 3, image 3 of 3
      Tool used on this step:
      Spudger
      $3.99
      Buy
      • Open the keyboard cover with a spudger
      • You will need to fold the display all the way back, or else the keyboard cover will get stuck on it.
      Ask FixBot
    1. Acer Extensa 4420 Keyboard Replacement, Keyboard: step 4, image 1 of 3 Acer Extensa 4420 Keyboard Replacement, Keyboard: step 4, image 2 of 3 Acer Extensa 4420 Keyboard Replacement, Keyboard: step 4, image 3 of 3
      $5.49
      Buy
      • Unscrew these 2 screws with a phillips #000 screwdriver.
      • Pull the keyboard out. It should come out pretty easily.
      • DO NOT PULL IT OUT TOO HARD, AS YOU WOULD BREAK THE RIBBON CABLE!
      • Flip the keyboard around, so you have access to the ribbon cable on the back of the keyboard
      Ask FixBot
    2. Acer Extensa 4420 Keyboard Replacement: step 5, image 1 of 3 Acer Extensa 4420 Keyboard Replacement: step 5, image 2 of 3 Acer Extensa 4420 Keyboard Replacement: step 5, image 3 of 3
      • Pull the white part of the connector towards you.
      • Doing so will unlock the ribbon cable.
      • Take the blue tag and pull it towards you.
      Ask FixBot
Author
with
TheMasterG
1,460 Reputation
12 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 70
All Time: 448
