Acer Extensa 4420 Hard Drive Replacement
    1. Acer Extensa 4420 Hard Drive Replacement, Battery: step 1, image 1 of 2 Acer Extensa 4420 Hard Drive Replacement, Battery: step 1, image 2 of 2
      • First, make sure that the battery lock is turned off.
      • The battery lock makes it so the battery doesn't accidentally fall out of your computer while it is running.
      Ask FixBot
    2. Acer Extensa 4420 Hard Drive Replacement: step 2, image 1 of 3 Acer Extensa 4420 Hard Drive Replacement: step 2, image 2 of 3 Acer Extensa 4420 Hard Drive Replacement: step 2, image 3 of 3
      • Then, slide the other battery lock while pulling the battery out.
      Ask FixBot
    1. Acer Extensa 4420 Hard Drive Replacement, Back Panel: step 3, image 1 of 1
      Tool used on this step:
      Phillips #00 Screwdriver
      $5.49
      Buy
      • Unscrew all five screws on the back panel with a Phillips #00 screwdriver
      • The screws will stay in the back panel, so when you remove it, you don't have to worry about organizing the screws.
      Ask FixBot
    2. Acer Extensa 4420 Hard Drive Replacement: step 4, image 1 of 3 Acer Extensa 4420 Hard Drive Replacement: step 4, image 2 of 3 Acer Extensa 4420 Hard Drive Replacement: step 4, image 3 of 3
      Spudger
      $3.99
      Buy
      • Take a spudger and start to pry open the back panel. Finish prying it open with your hands.
      • Be extra careful and try not to break any clips in this process.
      Ask FixBot
    1. Acer Extensa 4420 Hard Drive Replacement, Hard Drive: step 5, image 1 of 1
      • Start by removing these 2 screws.
      Ask FixBot
    2. Acer Extensa 4420 Hard Drive Replacement: step 6, image 1 of 3 Acer Extensa 4420 Hard Drive Replacement: step 6, image 2 of 3 Acer Extensa 4420 Hard Drive Replacement: step 6, image 3 of 3
      • Then, pull one of the pull tabs left.
      • This shouldn't take too much force.
      Ask FixBot
TheMasterG
1,430 Reputation
12 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 63
All Time: 306
