Up to 20% off select tools
Acer Extensa 4420 Back Panel Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
8
Past 30 Days:
58
All Time:
438
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. Acer Extensa 4420 Back Panel Replacement, Battery: step 1, image 1 of 2 Acer Extensa 4420 Back Panel Replacement, Battery: step 1, image 2 of 2
      • First, make sure that the battery lock is turned off.
      • The battery lock makes it so the battery doesn't accidentally fall out of your computer while it is running.
      Ask FixBot
    2. Acer Extensa 4420 Back Panel Replacement: step 2, image 1 of 3 Acer Extensa 4420 Back Panel Replacement: step 2, image 2 of 3 Acer Extensa 4420 Back Panel Replacement: step 2, image 3 of 3
      • Then, slide the other battery lock while pulling the battery out.
      Ask FixBot
    1. Acer Extensa 4420 Back Panel Replacement, Back Panel: step 3, image 1 of 1
      Tool used on this step:
      $5.49
      Buy
      • Unscrew all five screws on the back panel with a Phillips #00 screwdriver
      • The screws will stay in the back panel, so when you remove it, you don't have to worry about organizing the screws.
      Ask FixBot
    2. Acer Extensa 4420 Back Panel Replacement: step 4, image 1 of 3 Acer Extensa 4420 Back Panel Replacement: step 4, image 2 of 3 Acer Extensa 4420 Back Panel Replacement: step 4, image 3 of 3
      Spudger
      $3.99
      Buy
      • Take a spudger and start to pry open the back panel. Finish prying it open with your hands.
      • Be extra careful and try not to break any clips in this process.
      Ask FixBot
Author
with
TheMasterG
1,460 Reputation
12 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 58
All Time: 438
