Acer Chromebook R11 Battery Replacement
    1. Acer Chromebook R11 Battery Replacement, Battery: step 1, image 1 of 1
      • The back cover of the R11 is held into place using 11 screws.
      • To remove, use a screwdriver appropriate for a JIS 1 screw.
      Ask FixBot
    2. Acer Chromebook R11 Battery Replacement: step 2, image 1 of 1
      • Battery is located in the bottom half of the computer.
      • Unscrew the two screws holding the battery in place. There is one on each side of the battery.
      Ask FixBot
    3. Acer Chromebook R11 Battery Replacement: step 3, image 1 of 1
      • Slide out the ribbon that is connecting the battery to the motherboard.
      • There are 7 wires leading to it, and each is a different color of the rainbow.
      • Disconnect the keyboard ribbon located at bottom center of motherboard.
      Ask FixBot
    4. Acer Chromebook R11 Battery Replacement: step 4, image 1 of 1
      • Remove the battery by pulling upwards.
      Ask FixBot
10 other people completed this guide.
Jermaine Hannans
413 Reputation
1 Guide authored
USF Tampa, Team 1-2, Kass Spring 2017 Member of USF Tampa, Team 1-2, Kass Spring 2017
USFT-KASS-S17S1G2
4 Members
36 Guides authored
1 Guide Comment
Hi. Incidentally while you have it apart check for heating of the chip that controls the USB3 port: this is known to be a weak point. As with many low end laptops they can’t run external devices like hard drives properly so may report incorrectly that they need formatting. Fix is to use external power device.
Andre De Guerin - Reply Share
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 35
All Time: 10,778
