Acer Chromebook CB3-111-C8UB Key Replacement
    1. Acer Chromebook CB3-111-C8UB Key  Replacement, Key: step 1, image 1 of 3 Acer Chromebook CB3-111-C8UB Key  Replacement, Key: step 1, image 2 of 3 Acer Chromebook CB3-111-C8UB Key  Replacement, Key: step 1, image 3 of 3
      • Slide the plastic opening tool under the key you wish to remove until it is up against the bottom part of the key.
      • Then, lever the plastic opening tool. It should catch the key.
      • Finally, keep levering the key until it pops out.
      • We do this to avoid depressing the key. It becomes much harder to catch the lip with the key pushed down.
      Ask FixBot
To put the key back in place, simply push down on it until you hear the clips snap into place.
Travis Vo
426 Reputation
4 Guides authored
Cal Poly, Team 22-7, Maness Winter 2017 Member of Cal Poly, Team 22-7, Maness Winter 2017
CPSU-MANESS-W17S22G7
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 30
All Time: 930
