Acer Chromebook CB3-111-C670 Keyboard Key Replacement
    1. Acer Chromebook CB3-111-C670 Keyboard Key Replacement, Keyboard Key: step 1, image 1 of 1
      • Remove broken key(s) using the flat end of spudger.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular spudger and tweezer should be used whenever possible.
      • When reinstalling the key, no spudger is needed. Just pop it into place with fingers.
      Ask FixBot
    2. Acer Chromebook CB3-111-C670 Keyboard Key Replacement: step 2, image 1 of 2 Acer Chromebook CB3-111-C670 Keyboard Key Replacement: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Using the flat end of the spudger, very carefully lift up the corners of the cradle.
      • With the help of tweezers (needle nose works best), pull the hooks of the cradle out.
      • For re-installation of the plastic piece use tweezers to put it back in place and pop the bottom half in before the top.
      Ask FixBot
4 other people completed this guide.
Tony
461 Reputation
2 Guides authored
USF Tampa, Team 10-5, Remmell Spring 2016 Member of USF Tampa, Team 10-5, Remmell Spring 2016
USFT-REMMELL-S16S10G5
3 Members
36 Guides authored
1 Guide Comment
no help i need help putting it on with out that
Simon Kuhn - Reply Share
Past 24 Hours: 2
Past 7 Days: 23
Past 30 Days: 76
All Time: 9,432
