Acer Chromebook C740 Trackpad Replacement
  1. Acer Chromebook C740 Trackpad Replacement, Back Panel: step 1, image 1 of 1
    • Power down the Chromebook and disconnect the power adapter.
    Ask FixBot
  2. Acer Chromebook C740 Trackpad Replacement: step 2, image 1 of 2 Acer Chromebook C740 Trackpad Replacement: step 2, image 2 of 2
    • Place the chromebook bottom side up on a flat surface.
    • Remove the thirteen 7 mm screws with a Phillips #0 screwdriver.
    Ask FixBot
  3. Acer Chromebook C740 Trackpad Replacement: step 3, image 1 of 3 Acer Chromebook C740 Trackpad Replacement: step 3, image 2 of 3 Acer Chromebook C740 Trackpad Replacement: step 3, image 3 of 3
    • Insert the plastic opening tool into the slit near the hinges and pry upwards to lift the back panel.
    • Applying pressure may be necessary. A click indicates the panel is ready to come off.
    Ask FixBot
  4. Acer Chromebook C740 Trackpad Replacement, Battery: step 4, image 1 of 3 Acer Chromebook C740 Trackpad Replacement, Battery: step 4, image 2 of 3 Acer Chromebook C740 Trackpad Replacement, Battery: step 4, image 3 of 3
    • Unplug the white 8-wire battery connector from the motherboard by using a spudger to push the two L-shaped indentations towards the battery.
    • The connector is a tight fit. This process requires going back-and-forth between the two indentations and plenty of patience.
    Ask FixBot
  5. Acer Chromebook C740 Trackpad Replacement: step 5, image 1 of 2 Acer Chromebook C740 Trackpad Replacement: step 5, image 2 of 2
    • Remove the the two 3.7 mm screws with a Phillips #0 screwdriver.
    Ask FixBot
  6. Acer Chromebook C740 Trackpad Replacement: step 6, image 1 of 1
    • Lift the battery from the frame.
    Ask FixBot
  7. Acer Chromebook C740 Trackpad Replacement, Trackpad: step 7, image 1 of 3 Acer Chromebook C740 Trackpad Replacement, Trackpad: step 7, image 2 of 3 Acer Chromebook C740 Trackpad Replacement, Trackpad: step 7, image 3 of 3
    • Pull the black wire out from under the the black center clips and up from the gray outer clips with a spudger.
    Ask FixBot
  8. Acer Chromebook C740 Trackpad Replacement: step 8, image 1 of 2 Acer Chromebook C740 Trackpad Replacement: step 8, image 2 of 2
    • Use a spudger to lift the black clip on the small purple ribbon cable connector to the left of the touchpad.
    • Pull the ribbon cable out from the connector.
    Ask FixBot
  9. Acer Chromebook C740 Trackpad Replacement: step 9, image 1 of 2 Acer Chromebook C740 Trackpad Replacement: step 9, image 2 of 2
    • Remove the five 2.5 mm screws with a Phillips #0 screwdriver.
    Ask FixBot
  10. Acer Chromebook C740 Trackpad Replacement: step 10, image 1 of 2 Acer Chromebook C740 Trackpad Replacement: step 10, image 2 of 2
    • Remove the four 2.8 mm screws with a Phillips #00 screwdriver.
    Ask FixBot
  11. Acer Chromebook C740 Trackpad Replacement: step 11, image 1 of 2 Acer Chromebook C740 Trackpad Replacement: step 11, image 2 of 2
    • Wiggle off the silver bracket with your fingers.
    Ask FixBot
  12. Acer Chromebook C740 Trackpad Replacement: step 12, image 1 of 2 Acer Chromebook C740 Trackpad Replacement: step 12, image 2 of 2
    • Remove the black tape on the left side of the touchpad.
    Ask FixBot
  13. Acer Chromebook C740 Trackpad Replacement: step 13, image 1 of 2 Acer Chromebook C740 Trackpad Replacement: step 13, image 2 of 2
    • Lift off the black plastic cover with the plastic opening tool.
    Ask FixBot
6 other people completed this guide.
Flor De La Rosa
875 Reputation
4 Guides authored
Cal Poly, Team S22-G2, Livingston Spring 2017 Member of Cal Poly, Team S22-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G2
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 38
All Time: 3,048
