Acer Chromebook C740 Battery Replacement
  1. Acer Chromebook C740 Battery Replacement, Back Panel: step 1, image 1 of 1
    • Power down the Chromebook and disconnect the power adapter.
    Ask FixBot
  2. Acer Chromebook C740 Battery Replacement: step 2, image 1 of 2 Acer Chromebook C740 Battery Replacement: step 2, image 2 of 2
    • Place the chromebook bottom side up on a flat surface.
    • Remove the thirteen 7 mm screws with a Phillips #0 screwdriver.
    Ask FixBot
  3. Acer Chromebook C740 Battery Replacement: step 3, image 1 of 3 Acer Chromebook C740 Battery Replacement: step 3, image 2 of 3 Acer Chromebook C740 Battery Replacement: step 3, image 3 of 3
    • Insert the plastic opening tool into the slit near the hinges and pry upwards to lift the back panel.
    • Applying pressure may be necessary. A click indicates the panel is ready to come off.
    Ask FixBot
  4. Acer Chromebook C740 Battery Replacement, Battery: step 4, image 1 of 3 Acer Chromebook C740 Battery Replacement, Battery: step 4, image 2 of 3 Acer Chromebook C740 Battery Replacement, Battery: step 4, image 3 of 3
    • Unplug the white 8-wire battery connector from the motherboard by using a spudger to push the two L-shaped indentations towards the battery.
    • The connector is a tight fit. This process requires going back-and-forth between the two indentations and plenty of patience.
    Ask FixBot
  5. Acer Chromebook C740 Battery Replacement: step 5, image 1 of 2 Acer Chromebook C740 Battery Replacement: step 5, image 2 of 2
    • Remove the the two 3.7 mm screws with a Phillips #0 screwdriver.
    Ask FixBot
  6. Acer Chromebook C740 Battery Replacement: step 6, image 1 of 1
    • Lift the battery from the frame.
    Ask FixBot
7 other people completed this guide.
Flor De La Rosa
875 Reputation
4 Guides authored
Cal Poly, Team S22-G2, Livingston Spring 2017 Member of Cal Poly, Team S22-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G2
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 51
All Time: 8,268
