Acer Chromebook C732 Screen Replacement
  1. Acer Chromebook C732 Screen Replacement, Safety First: step 1, image 1 of 1
    • Make sure your device is turned off and disconnect your battery from the motherboard.
    • You can find a detailed guide for getting to and replacing this device's battery here
    Ask FixBot
  2. Acer Chromebook C732 Screen Replacement: step 2, image 1 of 1
    • Open the Chromebook so the display is facing towards you.
    Ask FixBot
  3. Acer Chromebook C732 Screen Replacement: step 3, image 1 of 2 Acer Chromebook C732 Screen Replacement: step 3, image 2 of 2
    • Using a plastic opening tool or a spudger, carefully pry the plastic bezel around the screen.
    • If you start in the corner, you should be able to release the tabs there. Once those tabs have been released, you can release the rest by hand.
    Ask FixBot
  4. Acer Chromebook C732 Screen Replacement: step 4, image 1 of 3 Acer Chromebook C732 Screen Replacement: step 4, image 2 of 3 Acer Chromebook C732 Screen Replacement: step 4, image 3 of 3
    • Remove the four screws holding the display in place with a Phillips #1 screwdriver.
    • Carefully lower the display to rest on the keyboard.
    Ask FixBot
  5. Acer Chromebook C732 Screen Replacement: step 5, image 1 of 3 Acer Chromebook C732 Screen Replacement: step 5, image 2 of 3 Acer Chromebook C732 Screen Replacement: step 5, image 3 of 3
    • The display connector is located on the back and is covered by some adhesive tape.
    • Carefully peal the tape back
    • Once the tape is peeled back, you can lift the bar to disconnect the display cable.
    Ask FixBot
2 other people completed this guide.
Jacob Mehnert
49,136 Reputation
51 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 29
All Time: 1,088
