Acer Chromebook C720-2848 Screen Replacement
    1. Acer Chromebook C720-2848  Screen Replacement, Screen: step 1, image 1 of 2 Acer Chromebook C720-2848  Screen Replacement, Screen: step 1, image 2 of 2
      • Insert a metal spudger around the inner side of the screens plastic perimeter.
      • Move along the perimeter while leveraging to pop the faceplate out like so.
      Ask FixBot
    2. Acer Chromebook C720-2848  Screen Replacement: step 2, image 1 of 2 Acer Chromebook C720-2848  Screen Replacement: step 2, image 2 of 2
      • Remove the faceplate's bottom hinges that connect to the body of the device with the metal spudger. This will free the plastic perimeter, which may now be removed.
      Ask FixBot
    3. Acer Chromebook C720-2848  Screen Replacement: step 3, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the 6 screws in these circled locations.
      Ask FixBot
    4. Acer Chromebook C720-2848  Screen Replacement: step 4, image 1 of 1
      • Reposition so the screen will lay flat on the keyboard of the laptop.
      Ask FixBot
    5. Acer Chromebook C720-2848  Screen Replacement: step 5, image 1 of 2 Acer Chromebook C720-2848  Screen Replacement: step 5, image 2 of 2
      • Locate the bar code adhesion strip at the base of the screen, and then peel it back carefully. Once peeled back the plug-in will come free.
      Ask FixBot
4 other people completed this guide.
Cory Provost
212 Reputation
1 Guide authored
USF Tampa, Team S9-G3, Remmell Fall 2017 Member of USF Tampa, Team S9-G3, Remmell Fall 2017
USFT-REMMELL-F17S9G3
4 Members
60 Guides authored
1 Guide Comment
In step 2, "the faceplate's bottom hinges" are plastic hinge covers that are (or, at least, were) part of the bezel. You may be able to take the bezel off while they're still attached, or you may have to break the flexing points so that they come off separately. Either way, it doesn't seem to cause a problem.
Thanks, Cory.
Lance ==)--------------
Lance - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 14
All Time: 2,185
