Acer Chromebook C720-2420 Memory Replacement
  1. Acer Chromebook C720-2420 Memory Replacement, Back Cover Replacement: step 1, image 1 of 2 Acer Chromebook C720-2420 Memory Replacement, Back Cover Replacement: step 1, image 2 of 2
    • Place your Chromebook upside down.
    • Utilizing the precision magnetized Phillips #0 screwdriver, remove all thirteen 6.5 mm Phillips screws that secure the back cover.
    • Before doing anything, make sure your Acer Chromebook is completely turned off.
    Ask FixBot
  2. Acer Chromebook C720-2420 Memory Replacement: step 2, image 1 of 1
    • Use the plastic opening tool to carefully remove the bottom.
    Ask FixBot
  3. Acer Chromebook C720-2420 Memory Replacement, Memory: step 3, image 1 of 2 Acer Chromebook C720-2420 Memory Replacement, Memory: step 3, image 2 of 2
    • Remove the 3.6 mm Phillips screw that secures the SSD in place.
    Ask FixBot
  4. Acer Chromebook C720-2420 Memory Replacement: step 4, image 1 of 2 Acer Chromebook C720-2420 Memory Replacement: step 4, image 2 of 2
    • Pull out the SSD.
    Ask FixBot
3 other people completed this guide.
Jessica Beckford
536 Reputation
4 Guides authored
USF Tampa, Team S15-G4, Boczar Spring 2018 Member of USF Tampa, Team S15-G4, Boczar Spring 2018
USFT-BOCZAR-S18S15G4
4 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 38
All Time: 803
