Up to 20% off select tools
Acer Chromebook C710-2833 RAM Module Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
85
All Time:
1,549
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 - 5 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
In this replacement guide, you will remove and install a RAM module.
    1. Acer Chromebook C710-2833 RAM Module Replacement, RAM Module: step 1, image 1 of 1
      • Flip your Chromebook over so the bottom is facing up.
      Ask FixBot
    2. Acer Chromebook C710-2833 RAM Module Replacement: step 2, image 1 of 2 Acer Chromebook C710-2833 RAM Module Replacement: step 2, image 2 of 2
      • Locate the 6 mm Phillips #00 screw that holds the back cover together. Use your driver with the PH00 bit attached to unscrew it.
      • Once completely unscrewed, carefully lift the cover off.
      • Place the screw and cover safely to the side for now.
      Ask FixBot
    3. Acer Chromebook C710-2833 RAM Module Replacement: step 3, image 1 of 2 Acer Chromebook C710-2833 RAM Module Replacement: step 3, image 2 of 2
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Now take your anti-static wrist strap and place it tightly on your wrist.
      • Attach the alligator clamp of the wrist strap to something that will ground yourself to avoid possible electric zaps.
      • The location chosen in the picture is recommended.
      Ask FixBot
    4. Acer Chromebook C710-2833 RAM Module Replacement: step 4, image 1 of 3 Acer Chromebook C710-2833 RAM Module Replacement: step 4, image 2 of 3 Acer Chromebook C710-2833 RAM Module Replacement: step 4, image 3 of 3
      • Locate the RAM module.
      • Squeeze the two metal clips on the sides of the RAM module to pop the RAM out.
      • Carefully remove from the slot.
      • When reassembling, stick RAM into slot and push down until a clicking sound is heard.
      Ask FixBot
Author
with
Nicholas Latorre
558 Reputation
5 Guides authored
USF Tampa, Team S1-G6, Nance Fall 2017 Member of USF Tampa, Team S1-G6, Nance Fall 2017
USFT-NANCE-F17S1G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 85
All Time: 1,549
