Acer Chromebook C710-2833 Fan Replacement
  1. Acer Chromebook C710-2833 Fan Replacement, Fan: step 1, image 1 of 1
    • Flip your Chromebook over so the bottom is facing up.
    Ask FixBot
  2. Acer Chromebook C710-2833 Fan Replacement: step 2, image 1 of 2 Acer Chromebook C710-2833 Fan Replacement: step 2, image 2 of 2
    • Locate the 6 mm Phillips #00 screw that holds the back cover together. Use your driver with the PH00 bit attached to unscrew it.
    • Once completely unscrewed, carefully lift the cover off.
    • Place the cover and screw safely to the side for now.
    Ask FixBot
  3. Acer Chromebook C710-2833 Fan Replacement: step 3, image 1 of 2 Acer Chromebook C710-2833 Fan Replacement: step 3, image 2 of 2
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Now take your anti-static wrist strap and place it tightly on your wrist.
    • Attach the alligator clamp of the wrist strap to something that will ground yourself to avoid possible electric zaps.
    • The location chosen in the picture is recommended.
    Ask FixBot
  4. Acer Chromebook C710-2833 Fan Replacement: step 4, image 1 of 2 Acer Chromebook C710-2833 Fan Replacement: step 4, image 2 of 2
    • Locate the two 6 mm Phillips #00 screws on the fan port.
    • Unscrew the two screws and place them aside for now.
    Ask FixBot
  5. Acer Chromebook C710-2833 Fan Replacement: step 5, image 1 of 2 Acer Chromebook C710-2833 Fan Replacement: step 5, image 2 of 2
    • Carefully remove the fan from its port. You may need to use a little force as there will be an adhesive on the right side of the fan keeping it in place.
    • Locate the Molex cable connecting the fan to its port in the top left corner.
    • Disconnect the cable.
    Ask FixBot
Nicholas Latorre
558 Reputation
5 Guides authored
USF Tampa, Team S1-G6, Nance Fall 2017 Member of USF Tampa, Team S1-G6, Nance Fall 2017
USFT-NANCE-F17S1G6
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 27
All Time: 1,201
